Hey folks, so I got four nice little leaks under my car. Pretty sure it's transmission fluid but I just wanted to know what the part was called and how I can go about changing it.
Pictures are attatched. It's the [dirty] silver pan there.
Cheers!
mate hard 2 c if oil is red its trans oil does it smoke hit the exhaust could be the front seal on trans or rear main if its oil gold black lookin try chase it if its red and comes out near the shaft its the seal on trans if its from the trans sump. gasket will do it replace filter while u there
thats the pan on the gearbox,it would probably just need a new gasket
Thanks adds_05
And what filter are you talking about bear76? Is there one inside there?
It's definitely a red coloured fluid which is why I thought transmission fluid.
I suppose this is going to drain a whole lot of xmission fluid when I take the pan off hey![]()
yer mate think its called transmission service kit best thing to do is get a big pan bigger than sump i undue front bolts first and leave last passenger side 1 on last few threads so it can tilt forward and drain it can get messy from memory yer there is a filter in there some 1 may post a how to do 4 u few things to consider on filter end is has a seal make sure that comes out if u do the filter dont use gasket goo dont need it from memory use a tourque wrench to do up sump as 2 tight can leak dont quote me on this but i think from memory do the bolts up too 11nm on the wrench and remember to clean the magnet in there attached to sump put this back same way come out hope it helps
Yes there is.The auto transmission filter is in there,and its worth keeping it serviced regularly.The filter costs $25 and it also comes with a new pan gasket (which could be whats leaking on yours anyway).You will need a 5 litre bottle of dexron 111 trans fluid as well.It pretty easy to change it,just undo and remove the transmission pan(be careful, the fluid will drain when the pan is loosesed),clean the pan and pan magnet with clean cloth (this magnet just sits on the bottom of the pan),remove the old filter and and its seal,then install the new filter with its new seal.If you run into any problems,you can post here anyway and someone will be able to help.And what filter are you talking about bear76? Is there one inside there?
If you want to do stuff like this on your car you should consider getting hold of a workshop manual.Well worth it.If you cant find a factory one ,then get a gregorys brand manual.
i drop mine every 12 months at least how far u wont to go i put a b@m drain plug in mine easier to drain advice on this is needed thou yes and the oil u need a lot
Thanks folks, I keep meaning to get a manual brett but things (like this) keep popping up and taking my spare cash! lol. Bit of a catch 22 if you ask me.
Thanks once again, appreciate it.
Just my two bobs worth but I'd reckon it's the front transmission seal - if was just a pan seal the oil always gets blown towards the rear plus you can usually nip the bolts up to stop a leak. If it is the transmission seal, doing the pan seal won't improve matters (especially your wallet) so if it was me, I'd clean the area and carefully check exactly where it is leaking from. Spray above the pan with spray degreaser then hose off...start the engine and run for a minute then have a look under the car to see where it's leaking from. If it is the front transmission seal, you will need to remove the transmission to replace the seal or add a can of 'trans stop leak'
Other possibles are the trans oil cooler connectors and the power steering rack which uses the same fluid.
Good Luck.
^^id probably give that ago,clean it all off first so you can see exactly where its coming from
I double that, my endless list is terrible. I think i get atleast 2 days inbetween before something else blows up.
Also i would check the power steering, check the reservoir levels. The oil can move like crazy, my reservoir was leaking and it was travelling all the way back to the transmission.
