Results 1 to 12 of 12
Thread: alternator question
    Vs Equipe
    Oct 2006
    Default alternator question
    hey all i have a vs commodore v6 i was wondering what type of alternator would i have and what the amps would be , im guessing its either 85 or 100 ???
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    bosch internal fan alternator.
    bxh1333 i'm pretty sure
    should be 85amp, unless its been replaced at some stage with the 100amp, or possibly the mitsubishi 120amp unit.
    Vs Equipe
    Oct 2006
    mitsubishi 120amp unit. is that actually a good quality unit i have a large soundsystem so the higher amperage would be better ? is it a direct fit or is modification neeeded
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you are upgrading the output of the alternator (more Amps) I would also upgrade the wiring from the B+ terminal of the alternator to the positive battery terminal. Your large system is pulling current out of the battery so the alternator needs to put it back in.
    Standard VS wiring in this circuit is at the maximum in standard form.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    the 120a unit is a direct fit, no modification needed to mount it. it was fitted to police, telstra etc vehicles
    although, as has been said, i would be also ugrading the cable from alternator to battery.
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    what would happen if you didnt upgrade it? where can one find these mitsy 120amp alternators
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I have one on my car, hasn't burnt any wiring so far and I run it to the max sometimes.
    I got mine directly from Holden, they were the cheapest place believe it or not, though I get everything for trade price. Interestingly enough the 120amp alternator is cheaper than the Bosch 100amp unit. I think I paid $280 or something.
    Ronald Reagan (1986)
    VR 3.8L
    May 2009
    you got a good price from a holden dealer? $280 for a brand new 120amp alternator?
    VX Berlina
    Apr 2007
    I can't find the receipt any more, but sounds about right.
    Vs Equipe
    Oct 2006
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by tiersum View Post
    how much would the B+ terminal cost
    the bolt on the alternator, or the ring part on the cable
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    The B+ terminal is the main connection at the back of the alternator. The cable that runs to the battery is bolted to it.
    Last edited by RX25SE; 04-05-2010 at 04:35 PM. Reason: oops...just saw the above post
  1. VR V8 Alternator question
    By stockyvrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2012, 09:01 AM
  2. alternator question
    By jabba13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 02:00 PM
  3. alternator question
    By Garth in forum Electrical Wiring / Questions
    Last Post: 17-09-2008, 10:09 PM
  4. Alternator question
    By neil001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 11:10 AM
  5. alternator question
    By VNcalais5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2006, 11:16 PM
