Results 1 to 15 of 15
Thread: weird question about tranny/ speed sensor/ whine
    vr acclaim wagon, vs wagon (project) & vx belina
    Apr 2010
    brisvegas
    Default weird question about tranny/ speed sensor/ whine
    i recently changed o ring that is on speed sensor on my vr acclaim wagon, the good thing is it now not leaking, the bad it seams to have a whine in that general area.
    i found it was coming from there , at slow speed i opened drivers door and can hear it, somewhere around the uni joint
    i can only hear it at slow speed once im doing 30klms or more i cant hear it till i slow down..
    when i changed the seal i lost about 3oo ml of tranny fluid
    do i need to replace this (the fluid)via the speed sensor sender hole or will it be getting fluid via the dipstick???
    i cheacked tranny when hot running in park and its full
    just this whine which in last few days has got louder and is rather annoying
    could it be the diff making this noise (travelling up tail shaft)
    also how do u chech diff oil level?
    vs commodore
    Oct 2009
    Tamworth NSW
    You top up the transmission fluid via the dipstick hole.Was the noise there before you changed the o ring seal?
    Apr 2010
    brisvegas
    vs commodore
    Oct 2009
    Tamworth NSW
    The speed sensor might not be sitting in the transmission properly.Id remove it again to check it out and make sure everything is as it should be.
    Apr 2010
    brisvegas
    yeah will do torrow, i had a llok today looks good, maybe its a diff noise.........
    i asume tranny fluid would drain as far back to speed sensor???
    is there some kind of bearing between tailshaft- tranny, maybe thats what all the noise is about
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by glennis View Post
    If the noise just started after you had the sensor out,I dont think that it will be the diff or the universal joints on the tail shaft making the noise.(unless you have undone something on them as well).It could be something to do with low trans fluid.Just fill it back up to the proper level then see if it still does it.The trans fluid will get back to the sensor no problems,just top it up the way I mentioned before through the dipstick tube..
    Apr 2010
    brisvegas
    yeah i have done all toping up, through dipstick, was just m aking sure fluid got back to sensor.
    still whines ,
    the fluid didnt look the best., but as i asked above is there a bearing at end of tail shaft tranny end?
    vs executive s1/ vz berlina
    Mar 2008
    Apr 2010
    brisvegas
    update:
    did a tranny service today.. was easier than what i thought....... until i had half done all sump nuts up and realised i forgot the filter....
    all in all went well after that
    looks like it hasnt had a servisin 370,00klms, as the filter was feral
    even better the whine has gone that was around the speed sensor( my original reason for opening this post)
    any one know total capacitly , for transmission/cooler?
    VS Commodore Series II V6
    Apr 2010
    Apr 2010
    brisvegas
    i sure did took me about a hr all up, saved my self $135 compared to the local mechanic/thief
    Apr 2010
    Apr 2010
    brisvegas
    yeah it comes as a kit from repco, (filter and corkgasket )
    fluid and service kit cost $ 54.00
    VS commadore V6
    Mar 2007
    Glennis, It says in my Gregory's manual a tranny service refill requires 4.8 litres....... [ total compacity 7.9 litres ] for a dry refill .
    It also says to check the level properly is to bring it up to normal operating temps, [ take it for a spin of no less than 24 klm ], then park it on a level ground whilst motor is still running, go through all the gears then put her in Park, then check the level and top it off if needed.
    good luck
  15. #15
    Apr 2010
    brisvegas
    ok thanks for that.. funny it has taken over 5 ltrs to fill it......
    when i dranned the sump and cooler it sat overnight. so it was completly empty.
    thanks all the same.
  1. Replaced Cluster and Speed Sensor, still won't show speed - only in ALDL
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 24-04-2009, 06:39 PM
  2. speed sensor removal question
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 12:19 PM
  3. tranny question
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2008, 05:27 PM
  4. Tranny question.
    By Joe2481 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2007, 10:09 PM
  5. speed sensor question
    By demonflesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 08:10 PM
