Results 1 to 6 of 6
Thread: installing cold air intake (need help)
    1997 vs ute ecotec v6 series 2
    Apr 2010
    newcastle/smiths lake
    Question installing cold air intake (need help)
    hey guys jus bought a new cold air intake and im aware i have to modify the existing box but i jus had a look an it seems like i have to remove the black casing around the radiator....Do i have to or will it fit if i screw to the top of the casing?
    the casing holds the radiator fan and im pretty sure i shouldnt have to remove it??
    jayce
    vr
    Jun 2009
    Yes, it just bolts to the top of the plastic on top of the radiator, if it is the gmh one. Just be careful when
    drilling the holes that you don't drill through the radiator.
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
    96 VS Acclaim
    Mar 2010
    One question on the subject, I've always wondered how the bonnet closes with the CAI ontop of the radiator there? Is there enough space for it to still close and how does the air enter through the bonnet if it's closed? :S
    Sorry for the semi-hijack.
    vr
    Jun 2009
    It still closes fine and does get enough air into it due to the air presure that flows over the front of the car when moving. They do suffer some heat soak though at a stand still.
    Apr 2010
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  1. [VR-VS] Installing L67 OTR Cold Air Intake to your VR/VS
    By HamaTime™ in forum Holden Commodore How-To's
    Last Post: 12-04-2012, 04:38 PM
  2. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  3. Cold Air Intake
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2010, 10:48 PM
  4. cold air intake on v6?
    By coveycoves in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2008, 06:34 PM
  5. INSTALLING A Cold Air Intake on vs 6
    By TOBSTA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2006, 11:00 PM
