Results 1 to 12 of 12
Thread: VS Wagon fuel economy
    VS Berlina Wagon 3.8
    Nov 2006
    Default VS Wagon fuel economy
    What ways are there to improve the fuel economy on my VS wagon? Taking for granted that pulgs, airfilter are good. I get 12/13 litre per 100 k from it.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by Kiwicommodore View Post
    whats the average and is that highway or city cycle
    Nov 2006
    Quote Originally Posted by moff_man View Post
    City, I drive an hour across town each way to work.
    moff_man's Avatar
    Nov 2008
    i would say thats normal i was getting that in my old vr sedan, now my vr wagon is getting 17 - 18 l/100 around town. highway you should get lower but it sounds good
    Nov 2006
    But I want better!!
    Would a chip help? Or would a different air claener setup?
    moff_man's Avatar
    Nov 2008
    OK some tips for fuel economy:
    basics,
    i use a 15w40 oil which at the moment is a diesel oil, to clean things out and its no different to 20w50 as far as I'm concerned
    auto serviced and in good condition
    alternator in good condition and battery also in good condition - modern cars need good electronics - on another note to electronics earth points, make sure there clean and tight
    tyre pressures set to 32 psi min, pump them up to 34 36 for better rolling down the high way, don't go above 40 psi (cold) (hotter tyers gain 2 - 4 psi when they get hot)
    excessive weigh in the car removed
    wheel alignment, toe set between 0 and 0.04 deg positive
    spark plugs air cleaner plug leads etc general servicing of the engine.
    failing all this a chip may improve the performance as well as economy
    vs commodore
    Oct 2009
    Tamworth NSW
    Just keep everthing serviced.The oil,fuel and air filters.If its auto,change the trans filter regularly.Carry as little weight as possible like tools in the back etc.Keep an eye on tyre pressures,run them near their maximum pressure.Jack it up and check for any brake drag or binding wheel bearings.I get better economy using 98 octane fuel than I do with the 91 octane unleaded fuel.Even though I get less at the bowser,I still go further than I would have on the same amount of normal unleaded,so that might be worth a try.Buggered oxygen sensors are the biggest thing to cause fuel consumption to rise.If the car has done 100,000 k's or more,theres a big chance they will need replacing.Every little bit helps when trying to get the best economy from your car.My VS V6 sedan gets around 10-12 litres/100 km in town.And around 6-8 litres /100km on the open road.
    Nov 2006
    Quote Originally Posted by Brett_jjj View Post
    Are the oxygen sensors easy to change and do they cost much?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I get 13L/100 around town (12 if I drive with a clenched ringhole) and about 8-9 on the hwy at around a dollar twenty.
    Car is is perfect condition tune wise and has new genuine O2 sensors.
    Nov 2006
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Could a pod filter help, rather than a cai?
    Doubt it.
    Pod filters tend to suck hot (less dense) air from inside the engine bay.
    VUII SS
    Mar 2008
    12l/100km city driving in a 15 year old car is pretty damn good!
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-09-2010, 12:30 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  4. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 09:01 AM
