swapped dash cluster for a berlina & have no displays. im sure both harnesses are plugged in ok. please help
Is it a level 3 cluster with 3 LCD windows?
The Daily VN T5V6
355 VN GRP A REP
yes its a 3 window dash for distance to empty speedo reading etc
pluged the connector in the bottom
other thing is to check the park light fuse.
bottom connector is plugged in, does the park light fuse power dash display ? another problem is heater/air con fan comes on when light switch is turned on
did u replace a 3 window cluster.... for a 3 window cluster,.... or upgrade from lower spec cluster?
both dashes are the same, berlinas with cruise & climate air
might wanna check the pcb on the back make sure its pin to pin corect.. its written on there what each connector is,
just removed my fuse 1 under steering column and dash went out, turned the key to acc and fan come on(display was off). (fuse 1 is park lights and trip computer)
