Results 1 to 12 of 12
Thread: vr commodore will not start!!
    richie351 is offline statesman driver n luv it
    VRcommodore
    May 2009
    w.a
    Default vr commodore will not start!!
    hey i brought commodore cheap for project .. it would start for like 2 seconds then die.. we banged the fuel tank it started up n ran fine.. got it home tryed to take it off trailer now it wont start.. fuel pump sounds ok when i turn the key on .. took spark plug out n put it in the lead n put it against the body and got no spark can someone please help .. thanks you
    I NOTICE HOLDEN DESIGNED ITS BADGE ROUND DUE TO CIRCLES GO ON FOR EVER..
    VT clubsport R8
    Apr 2010
    what sort or engine is it? could be distributor, ignition mudule or the computer
    VRcommodore
    May 2009
    w.a
    the series 2 ecoteck. the guy i got it off told me they put the series 2 engine in it
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    VRcommodore
    May 2009
    w.a
    i got 1 flash break 2 flash long break.. so 12.. meaning all is fine
    vx s pack II
    Jan 2010
    aLKIDA
    The ecotec motor have no distributor.
    If there is no spark it can be either the coils,DFI module,CAS,EFI relay
    VRcommodore
    May 2009
    w.a
    i read on another post about a v6 commodore not startin guy said he cleaned terminals n it started fine
    vx s pack II
    Jan 2010
    aLKIDA
    I am guessing you are talking about the DFI module plug. If so give it a go and see what happens. Other wise what i said before.
    VR 3.8L
    May 2009
    did you wait for it to flash 3 times, alot of people forget this. if its not starting it should have logged an error. have ou disconnected the battery recently? If it worked for them it may work for you. check battery and electrical connections are tight and then try replacing the DFI module.
    ethann's Avatar
    ethann is offline Low And Luxurious!
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Dec 2009
    Newcastle, NSW.
    Ecotec in a vr?
    So its had a engine conversion?
    How trustworthy was the fella that you got it off? Might have a fauly plug somewhere.
    VRcommodore
    May 2009
    w.a
    what is the DFI moduel ?? thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by richie351 View Post
    DFI (Direct Fire Injection) module is the module that the 3 coils are attached to.
  1. 1996 vs commodore v6 will not start
    By st3ev in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 02:21 PM
  2. VS Commodore won't start
    By otis33 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2010, 11:44 PM
  3. vn commodore wont start
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2010, 07:28 PM
  4. vt ss commodore wont start
    By steve67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2009, 08:26 PM
  5. vs commodore help..wont start
    By 21AZE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 11:08 PM
