Results 1 to 3 of 3
Thread: Code 36 - Vacuum Leak Vr SS
    VT S2 Club Kitted, VR SS, VL Executive
    Oct 2005
    Broken Hill
    Default Code 36 - Vacuum Leak Vr SS
    Ok installed new throttle body, etc working fine UNTIL i go over 3k revs, then engine light comes on, then turns off again when i go back to normal idle, checked error codes etc and came up with this, the car drives rough afterwards through gear changes, won't select 3rd or OD.
    Turn the car off and start up again and drives perfect UNTIL i floor it again.
    Just need an idea where the "vacuum hoses" are i guess heh.
    Thanks
    VX II Calais LS1
    Jan 2010
    Did you re-connect all the vacuum lines to the throttle body ? and the 2 wiring plugs?
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    Oct 2005
    Broken Hill
    Sorry took so long to reply yeah they seem fine, if i spray some "start ya bastard" on the throttle body around the hoses etc, i should be able to notice if they are actually sucking air?
  1. Vacuum Leak?
    By WinterVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 12:39 AM
  2. vr v6 code 36 vacuum leak
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2010, 06:22 PM
  3. vacuum leak?
    By unregistered in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-12-2009, 02:57 AM
  4. code 36 vacuum leak???
    By 5.0L UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2008, 12:55 AM
  5. Error Code 36 - Vacuum Leak
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2006, 11:26 AM
