Results 1 to 9 of 9
Thread: Double row timing chain - cam sensor?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Double row timing chain - cam sensor?
    There is no hole for the cam sensor magnet on the rollmaster double row sprocket. Do i simply not use the magnet?
    vs commodore
    Oct 2009
    Tamworth NSW
    The engine will run like crap ,and there will be errors set in the ECU and the engine light on the dash will be on if there is no cam angle sensor signal.Ive driven a V6 with a stuffed cam angle sensor and it ran terrible like it wanted to stall at idle all the time.
    Dec 2008
    So what do i need to do? This is definitely the right product, it says "ecotec" on the box. Surely Rollmaster wouldnt make a product that ****ed your car as soon as you install it.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its a T5 and is running a manual tune it wont be useing it anyway so just leave it out even auto it will just revert to firing all the injectors at once like vn you cant normally tell the difference when driving weather its plugged in or not
    в∞ѕтεכ √&
    Jul 2008
    NZ
    oh flag the last post forgot it was ecotech not vr LOL
    Dec 2008
    Edit. ^^ Bugger. So how does Rollmaster expect us to use this product? Anyone use it? Is there a way to tune around it?
    vs commodore
    Oct 2009
    Tamworth NSW
    If its just a solid metal cam gear, maybe you can get someone to drill the hole through it so the cam angle sensor magnet can be fitted.
    Dec 2008
    I just rang Romac and apparently this is one of the older batches designed for racing purposes. They said send it to them and they'll replace it with one that has the magnet hole.
    vs commodore
    Oct 2009
    Tamworth NSW
    Good one,an easy fix.Too bad they didnt mention that there are different ones available first time..
  1. vs.. double row rollamaster timing chain
    By crzyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 10:54 PM
  2. Fitting double row timing chain
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 09:43 PM
  3. [Ecotec] Double row timing chain worth it?
    By maldotcom2 in forum V6 Development And Modification
    Last Post: 07-02-2010, 07:58 PM
  4. vr v6 roll master timing chain sensor
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2008, 06:46 PM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
