Results 1 to 3 of 3
Thread: Vs statesman climate control problem
    vs statesman III 98
    May 2010
    Default Vs statesman climate control problem
    Climate control panel has an x on it most of the time.When the x is on all I get is hot air out of the vents.The air con will only blow hot air when the x is on.I also have an issue with a lot of hot air coming out from under the dash.Ihave noticed that the pipes going to the heater box dont have any insulation on them thus generating alot of heat.Should the pipes be insulated?The heat is that intense that you need to drive with the window open.Can anyone help?
    vs commodore
    Oct 2009
    Tamworth NSW
    Try this.I found it on here.It puts the climate control into diagnostic mode.It might give you an idea of whats wrong.(Hold "amb" and turn the ignition on, then press "off". Release buttons. That gets you to the screen test. Press "amb" again and that takes you into the diagnostic mode. "Up" and "Down" buttons take you through the diagnostics, along with "amb", but I haven't got the "addresses" at the moment.) Let us know how you go.
    vs statesman III 98
    May 2010
    Thanks Brett.I will give it a go and let you know.
  1. statesman dash + relocating climate control?
    By fergie_vs in forum General
    Last Post: 06-08-2009, 08:35 PM
  2. wh statesman climate control
    By flamingo joe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-04-2009, 08:46 PM
  3. HELP - WH statesman dual zone climate control, interior fan no work
    By Caprice5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2008, 06:15 PM
  4. statesman climate control to vn
    By 5speedcalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 10:56 PM
  5. VS Statesman Climate Control Problem
    By Wingnut0021 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 12:03 PM
