Results 1 to 3 of 3
Thread: Long Range Fuel Tank Questions.
    vs commodore
    Oct 2009
    Tamworth NSW
    Default Long Range Fuel Tank Questions.
    I am trying to find out if I fit a VN long range fuel tank to a VS V6, can I run the one single internal fuel pump .The VN's with the long range tank fitted had two electric fuel pumps.One internal and one external.So I thought Id find out if anyone has done this and used just the single internal pump.Thanks.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Sorry to hijack, but when did they change from a two pump setup to one?
    I would proberly look at converting the one in my VN to a single pump setup if there the same?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Dec 2009
    The VN's fitted with a long range fuel tank have an internal priming pump and the external pump is the high pressure pump. I've checked my VN factory manual and the internal priming pump is a fair bit shorter than the internal high pressure pump found on the normal petrol tanks in a VN and up to VS. I can't see why you can't modify the pickup if nessesary to take the longer high pressure internal pump and the pulsator etc.
    From memory when I was getting a new tank for my VN the VS tanks have different breather connections, the VN has one big one and 2 small ones so you may have to block one up and also the fuel return goes onto a barbed fitting on the front of the tank and not the sender unit.
  1. Long Range Fuel Tank...
    By Frandy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2006, 07:55 PM
  2. WTD: Long Range fuel tank 90l for VC
    By ssberlina in forum Swap / Wanted to Buy / Trade
    Last Post: 19-03-2006, 12:29 AM
  3. Wtb: Vlt Long Range Fuel Tank
    By YKORAY in forum Swap / Wanted to Buy / Trade
    Last Post: 11-09-2005, 04:23 PM
  4. VS UTE Long Range Fuel Tank
    By cleggy88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2005, 12:03 AM
