Results 1 to 6 of 6
Thread: VS Diff and rear shocks.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Default VS Diff and rear shocks.
    Hi,
    I got my first car two nights ago, 96 Commodore VS Equipe. The car can be rocked sideways at the rear end about 16cm (It does not have IRS). The fuel and temperature gauges are *sticky* they skip up and down. The reading still looks right but it is annoying. How should I go about fixing this? And does anyone know what type of diff it has? I've been told its a locker.
    VY SS
    Jun 2006
    Albany
    Id say the shocks are stuffed just get some new ones, i think mine cost $120 for both rears. And the diff will only be an open single spinner diff.
    Vp S1 Exec
    Jan 2010
    The panhard rod bushes worn and are easily replaced causing the movement in the suspension. Also the instrument cluster will have to be removed and a unit inside the cluster soldiered to rectify the sticking guages. There is a thread on this in this forum in the vn/vp section
    Sti Subaru Melbourne "the home of Sti"
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Thank you for replies. I have to remove the instrument cluster to fix the odo aswell. Heres link to sticky gauges
    Solution to Sticky fuel/temp guages
    Is the wiring the on the VS cluster the same as the VP?
    Vp S1 Exec
    Jan 2010
    from my limited holden know how on a series1 low level cluster they are very similar, i think the left hand indicator runs on another circuit but not sure. i know ive put vr guages into my vp cluster that work a treat!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Make sure you disconnect the battery before you pull the dash otherwise you may end up setting fault codes.
  1. Rear shocks
    By madcowmc in forum General
    Last Post: 26-01-2010, 05:51 PM
  2. rear shocks etc
    By Brucefromruse in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2009, 07:54 PM
  3. rear shocks??
    By dagar187 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-02-2007, 06:02 PM
  4. WTB lowered rear shocks suit solid rear axle
    By VS SII in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2006, 09:27 PM
  5. VS and rear shocks
    By HQ_Kid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2005, 03:01 PM
Tags for this Thread
