Results 1 to 6 of 6
Thread: VS park switch problem
    VR Executive
    Oct 2007
    Default VS park switch problem
    Hi guys had a problem with my VS auto yesterday wouldnt start but would turn over in all gears so called the RAA. they said my fuel pump was stuffed and that is why it wouldnt run. i tested the fuel pump and it was working fine so i checked all my fuses and relays all seemed to be fine then tryed again and it started. now my problem is i checked the park switch and its working fine i even tried another switch but it will turn over and start in all gears is there any other switch i should be looking at any help would be great
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    VR Executive
    Oct 2007
    It was fine last week never had a problem till the other day also today i took out the switch and the car still starts in all gears. just cant work it out
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    do your reverse lights work, because they are in the same switch.
    sounds like you might have a short somewhere in the wire between the switch and the relay...
    any mods done to the car recently?
    vr acclaim
    Apr 2010
    i know on vr if inhibitor switch is faulty it will start in any gear try checkin this 2 on floor shift its near shifter colum its near linkage underneath as i say this happens on vr not sure bout vs worth a look thou
    VR Executive
    Oct 2007
    yeah reverse lights work fine and the car is stock no mods at all. also tryed the key without the black part and it started as well its got me stumped
  1. Park Lights on while switch is set to off
    By Anwyll in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-05-2010, 10:44 PM
  2. vt a/c switch problem
    By spudly in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2009, 09:58 PM
  3. park selector switch - bypassing
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-04-2006, 06:37 PM
  4. Ignition Problem in the Car Park F**K HELP!
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2005, 10:07 AM
  5. vs ignition switch problem
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2005, 01:26 PM
