Results 1 to 5 of 5
Thread: cruise brake switch question
    VS commadore V6
    Mar 2007
    Default cruise brake switch question
    I am starting to get all the parts ready to install cruise control, but just wondering if the cruise brake switch has a nut on the end of that plastic thread to lock it into position once installed.
    The Holden wrecker were I got it didn't have a clue, tried searching here but couldn't find anything about any nut. [ i have got the little steel bracket that the switch goes into ]
    Appreciate any help.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'Day Rony, the spring steel washer thingo first pushes into the hole in the bracket and then the switch simply pushes in...it will go click,click as it pushes in further till it meets the brake pedal proper. The setup results in a switch that seems pretty loose in my opinion but it seems to work although twice I've had to readjust this switch. Good Luck.
    VS commadore V6
    Mar 2007
    Hi Hako & thanks for your reply, I also thought it was a bit loose as well, perhaps a very slight bending inwards on the steel clip may make it hold a bit better.
    thanks mate.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I thought exactly the same but was a bit worried that I might bugger it up so I left it alone.....still not really happy with it sloppy but it hasn't given a problem for over a year now. Regards.
    VS commadore V6
    Mar 2007
    I wasn't happy with mine being so loose [ when the wreckers pulled it out i am sure they bent the lugs a bit ] so I just bent them back in a tiny bit so they would grip the plastic thread better, it isn't so loose now, shall see how it goes, fingers crossed.
  1. Brake/cruise switch keeps popping out :S
    By shezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2010, 12:49 AM
  2. Changing Brake switch- VX
    By Bax in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-04-2010, 08:26 AM
  3. cruise control brake switch
    By w1war3na in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2010, 06:29 PM
  4. Brake Light Switch
    By ElDubya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2010, 02:48 PM
  5. brake switch
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2006, 10:36 PM
