hi all
few days ago i took out the instrument cluster to try fix my fuel gauge issue.. when i put it back it now my speedo wont work.. needle isnt sticking and it worked fine before..
when i realised my speedo wasnt working i thought i would just use digital speedo on speed alert but to my surprise this wasnt working either.. cant understand whats happening as it was all good and all i did was pull gauges out to check fuel side, i didnt touch the speedo side at all apart from removing needle to get under the plastics...
any help would be greatly appreciated as its getting hard to drive the legal limit when i dont know how fast im going..
TIA
only milk and juice should come in 2 litres
Did you solder up the voltage regulator while it was apart? Have you plugged the speedo connector in to the back of the speedo?
I would be sus of the PBC backing on the cluster One of the copper tracks may be broken.
and 3 Dangerous non ABS VN's
no voltage reg turned out fine so i dusted it off and put it back in.. speedo was plugged in at back, checked this many times.. i decided to rip it back out and follow your advise checking the PCB backing, one of the tracks was broken. it was the "pulse ground" one. remembering a post i read about fixing these i carefully scrapped it back either side of break using a blade and cut thin strip of foil. then useing clear tape i stuck strip of foil over to bridge where it was broke..
i will put it in in the morning and see if it fixed it..
thanks for the advice mate![]()
damn, put it back in just then took it for a test run and still not working... fuel gauge is now working though.. and the digital speedo on the speed alert isnt working either.. dont want to replace guage until i know thats where the problem lies as it was fine before all this..
is there a fuse for teh speedo?
i couldnt find one, just one for the instruments and that was ok
It's either the speed sensor, wires between, dash plug or cluster. If you only touched the cluster = No 1 suspect.
Long shot here - But did any of the dash plugs pop out when the cluster came out. I have seen cars with them in the wrong way around.
worth a look at the plug. the one with speedo came out, but i thought there was only one way to put them in.. i will go check that..
and i agree about the cluster being the number 1 suspect..
When you say the voltage regulator looked fine - did you re-solder anything?
The speed alert not working says to me it's not getting pulse signal from the speed sensor. And the fact that the speed sensor has not been touched.
It will be the cluster PCB, wire connector or voltage regulator
no i didnt solder anything. i had a close look at rhe pins and they all looked real good, looks newer then anything else under their. i about to go see if i put that plug in arse up
Do a very good close inspection of the PCB on the back of the cluster and also check the part that mates up with the dash plugs - can be bent back on itself and not make contact.
