hey guys another post .. commodore had no spark dad fiddled with the wired under the dash n it started the problem i had 1st .. it would start for 2 seconds n die... i bridged toe computer put it in limp mode to see if the computer said it had any problems it said system fine.. so i tryed to start it while in limp mode it fired up fine idled reved the lot.. ran 100% so i pulled the wires out to un bridge it.. and turned it off n it starts fine each timedoes anyone have any idea what could be wrong.. all i did was gave it a fuel filter change thats it
any help would be good thanks
I NOTICE HOLDEN DESIGNED ITS BADGE ROUND DUE TO CIRCLES GO ON FOR EVER..
It might be a long shot but check the wiring that goes to the fuel pump under the car at the rear near the fuel tank..You might have bumped it and partially broke a connection while replacing the filter.Try wiggling the wiring around as the car is cranked over.You should be able to hear the pump running.If you move the wire with the bad connection then the pump will stop and start.This wiring section gets knocked around a lot and battered as its exposed and under the rear of the car,it can get little breaks in the wiring etc,so have a good look at it.The fuel pump should run for 2 seconds then stop when the ignition key is turned to the on position.You should be able to hear it.
ive already cut the white dodge plug out and joined the wires up .. my last commodore the plug stuffed up .. i thort that was the problem.. so cleaned that up.. its starting fine now.. but i wanna solve the problem so its reliable.. cheers
it may just have been that there was air in the fuel line/filter after the replacement that took a bit to get through?
