Results 1 to 10 of 10
Thread: Buick series 2 to 1
    VR Executive S2 Wagon
    Apr 2009
    SA
    Default Buick series 2 to 1
    Hello
    I got me a series 1 buick that was rebuilt with new heads and what not. so i want to put it into my vr series 2 car is it was easy as just taking out the old engine and putting this one in? as the only thing i can see that's different is that it does not have one socket for one of the cables on the side where you have your oil filter and the water pump.
    (note this engine came out of an VR feb 94 and mines a VR DES 94)
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    there is also a plug at the back of the inlet manifold, im not 100% sure if the s1 vr's had this (i think its for air temp)
    Apr 2009
    SA
    Well there is one in the back of the manifold. but if i put the engine in what do i do with this spare plug? or does it go some where else.
    Apr 2009
    SA
    Found out its the cam sensor as the series 2 has one the the series 1 does not does that mean i just leave it there and plug it into nothing or???
    moff_man's Avatar
    Nov 2008
    you can use the front plate from your old engine and the pully other wisw the check engine light may be on
    vs commodore
    Oct 2009
    Tamworth NSW
    I fixed a VS a while back that had a broken cam angle sensor pickup magnet, it kept stalling at idle and just ran terrible until I replaced the magnet for the sensor.(The magnet had actually hit the inside of the sensor which snapped the little plastic cage that holds the pickup magnet in the camshaft drive gear).It ran perfect with the new pickup magnet.I wonder if a disconnected cam angle sensor would have the same effect on how the earlier type V6's run.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    what enfine is it series 1 vn or later vp or a manual vr engine they all have no cam sensor you can run without it will get error codes should run the same though.the ecu just fires all the injectors at once instead of one side of the engine then the next
    Apr 2009
    SA
    Hold on after looking at my car and the engine i got and me new one they look 100% the same i do not know what i was thinking with this other sensor how do you tell a series 1 from a 2?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vr all engines are the same apart from between auto and manual having that sensor in auto and not in manual vp engine looks very similar vn has the top radiator hose at the rear of the engine
    Apr 2009
    SA
    I feel so silly now as the engine is the same. so i got me answer to this topic.
    thank you all for your help
  1. [WA] WTB: VR Buick engine of any series
    By VryNeat in forum Swap / Wanted to Buy / Trade
    Last Post: 18-04-2009, 10:58 PM
  2. vn-vr buick
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2009, 03:00 PM
  3. Buick Series 1 and 2 inlet manifolds
    By 202injected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2008, 09:13 AM
  4. buick v6.
    By VRV6BT1 in forum V6 Development And Modification
    Last Post: 16-04-2008, 02:11 PM
  5. VH Buick 3.8 Help/Q's
    By pro_gmh in forum General
    Last Post: 24-02-2006, 05:58 PM
