Results 1 to 10 of 10
Thread: Replaced fuel pump, missing big time.
    vs
    Jan 2010
    Unhappy Replaced fuel pump, missing big time.
    I just replaced the fuel pump. Put in a new fuel filter and replaced the spark plugs.
    Now the car is missing and backfiring heaps.
    It seems to idle OK, but when you put your foot down it starts missing, dies a little bit.
    When driving, unless you only lightly touch the accelerator, cough cough splutter splutter.
    Thought it might have been a batch of dodgy plugs so swap them for the old ones.
    Any ideas?
    I'm thinking of pulling the fuel pump out again and anyone who has done this knows how much a pain in the neck it is to do.
    vs commodore
    Oct 2009
    Tamworth NSW
    If you have silicon type plug leads, the carbon core inside them can break very easily which renders the lead useless as they cant be repaired.You only have to pull on them a bit too hard when removing them from the plugs, or kink them a bit, and thats enough to break the core in them.Try another set of leads or borrow a lead and try it in place of each of your leads to see if you can find if one is broken(or breaking down under load).If it was running ok before you changed the plugs ,and you have tried the old plugs again ,and the same thing is still happening,then its a big chance that one of the leads is causing the problem.
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Sounds like leads, make sure they're on nice and tight. If it was the fuel pump it probably would just be completely dead no backfiring.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Triple check that the plug leads are on the correct plugs.
    vs
    Jan 2010
    I have a spare set of leads, I'll put them in tomorrow.
    The leads should be on the right plugs. Thinking ahead and realizing that I would forget which lead went to which plug, I did them one at a time.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    i had the exact same problem and i replaced the leads and now she runs sweet as
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    vs
    Jan 2010
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    vs
    Jan 2010
    Quote Originally Posted by The1 View Post
    got the fuel filter on the right way, has happened.
    You've got me doubting myself now. I think I am just going to have to bite the bullet and pull it out again to check.
    vs
    Jan 2010
    Yahoo! I had another set of leads, so I thought I would try this before checking the fuel pump.
    Problem solvered!
  1. where can i get my fuel return line inside the tank replaced?
    By b3h3m07h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2010, 01:44 AM
  2. Car wont turn over. Soft ticking. Just replaced fuel pump.
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2010, 07:41 PM
  3. fuel pump replaced, car still not starting
    By crewsy in forum V8 Development and Modification
    Last Post: 21-08-2009, 05:00 PM
  4. Anyone Replaced fuel tank on vs v6?
    By Diesel_Boy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2009, 06:46 PM
  5. How much fuel pump replaced by mechanic?
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2008, 08:15 PM
