Results 1 to 10 of 10
Thread: vs commodore wipers and indicaters conked out
    1992 vp calais
    Mar 2010
    Default vs commodore wipers and indicaters conked out
    today while driving in the rain my washers wipers and indicaters just went out wouldnt work anymore. i called the R.A.C.V the bloke came out changed the the fuse for them after putting a new fuse in the new one just blew again he said it couldnt be fixed on the spot and i needed to take it somewhere to get it looked at. any ideas on where i should take it (auto elctrician) or mechanic, and has anyone come a cross this problem before? and if so what neede to be done to fix it. help would be appreciated.
    vs commodore
    Oct 2009
    Tamworth NSW
    The indicators and wipers share the same fuse,which is fuse number 14 under the dash..Id unplug the wiper motor ,then re install a new fuse,and see if the blinkers work ok.If they do and the fuse doesnt blow again,the problem is going to be in the wiper motor circuit.It could be the wiper motor has shorted out internally,but check the wiring going to it first.If theres no obvious short found, like bare wires etc,then try another wiper motor.If the wiper motor is unplugged and the fuse still blows,then check the blinker wiring,especially around any trailer plugs,and in the boot area.
    VS Commodore Series II V6
    Apr 2010
    It could be rain related in a sense that water got in the engine bay, hows your guttering in the front of your car, that could overflow and short the motor out, is the car dry now? have you tried the fuses again? for sure follow brett advise.. just a thought about the water and "rain" factor.
    1992 vp calais
    Mar 2010
    yeah the guttering isnt the best in the sense its got a few cracks. yeah the ca is dry now ill try a new fuse for it see how it goes if it still blows out ill have to get a new wiper motor. umm where is the wiper motor located. and is it hard to diconnect?
    vs commodore
    Oct 2009
    Tamworth NSW
    You have to remove the windscreen wipers. Remove the large plastic nuts from the wiper shafts.Remove the rubber weather strip from the top of the firewall.Prise off the plastic leaf guard clips from below the windscreen and then remove the leaf guard from the vehicle.Remove the wiper motor earth lead screw to the body.Disconnect the wiring connector from the wiper motor.Remove the bolts retaining the wiper motor and linkage assembly to the plenum chamber.Manoeuvre the wiper motor and linkage assembly from the plenum chamber.
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    before you go tearing the plastic cover off, note: it is extremely sensitive after all these years, and will crack REALLY easily, be careful.
    1992 vp calais
    Mar 2010
    ok ive done all that but my plastic cover is already cracked and me taking it off cracked it even more this is probably the reason the motor conked out in the first place water got in there. is there any chance of getting a new one and what are they called ? (plastic cover) btw i bought a new wiper motor for 40 dollars did i get ripped off ?
    VR Executive S1
    Mar 2009
    The plastic cover you can get from a wrecker or Holden, I'd say your problem lies in the wiper motor put the new one in and if the fuses still blows the poblem may be with the relay box getting water in there could have stuffed it but thats just a guess about the relay box so don't freak out lol, try the new motor and see what happens.
    The God's envy man, for man is mortal and everything that man witnesses in life is more beautiful.
    Apr 2010
    1992 vp calais
    Mar 2010
    (luvmycommodore) yeah i changed the wiper motor pickup up one for 40 dollars and then i changed the fuse for the wiper/indicaters and now everythings in good running order i think the problem was that the plastic cover was cracked so when raining water got to the wiper motor. so im tryna look for a new plastic cover. thanks for the help
  1. engine conked out>VS Berlina wont' start
    By hj to vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2009, 07:31 PM
  2. wl statesman indicaters on to vt???
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2009, 04:35 PM
  3. indicaters
    By vn aero249 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2008, 11:32 AM
  4. Vt Commodore wipers
    By Zaretti in forum Electrical Wiring / Questions
    Last Post: 05-06-2008, 06:48 PM
  5. car conked OUT!!!
    By VTPREDATOR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2007, 06:40 PM
