Results 1 to 6 of 6
Thread: Super6 Supercharger Servicing??
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    Default Super6 Supercharger Servicing??
    Hey guys.
    Reading some old school holden tech articles, Saying that the supercharger oil needs to be serviced everyonce in a while.
    Anyone have any idea on how to do this?
    Thanks.
    47 made with the 185i engine $62,500 new
    35 made with the 215i engine $73,500 new
    VS L67
    Sep 2007
    BrisVagus
    A quick, clean and easy way to do it is as follows.
    1. Get a trigger spray pack and take the trigger unit off the bottle so you have the pick up pipe and the trigger unit.
    2. Undo the filler plug on the side of the blower, this is the silver looking plug that has needs an allen key to undo it.
    3. Place the pick up pipe of the trigger spray pack in the hole and start to pull the trigger, make sure you have a container to catch the oil in.
    4. Keep pumping until all the oil is out
    5. Refill with the correct oil for the supercharger, the Holden stuff is stupidly expensive, the Yella Terra oil is far better priced.
    6. Do not over fill.
    Be warned the oil smells really, really, REALLY bad.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    VS Calais
    Mar 2010
    Q: How often do I need to change the oil in my supercharger?
    A: The sealed oil reservoir in a supercharger is designed to last the life of the vehicle. Changing the oil is not recommended unless you suspect contamination, leakage, or other issues like bearing failure. Also, if your vehicle has an abnormally heavy duty cycle, such as racing or towing, you could consider changing the oil at regular intervals such as 20k, 30k, 50k, or 100k miles depending on usage
    Taken from the eaton website.
    Spin
    Quote Originally Posted by destiny View Post
    wtf? im not stupid, theres no such thing as a tyre valve
    vs commodore
    Oct 2009
    Tamworth NSW
    VS Calais
    Mar 2010
    I did, the Calais has 225k on the clock. While changing the belt I found quiet a bit of "slop" at the pully. I orderd a new part, pulled the snout off and put new oil in. I will chaing the oil again at 250k just to be sure.
    Spin.
    pedrotski's Avatar
    Jan 2008
    Mandurah
    the car has 240,000k's, the guy before me owned itsince 150,000 and never serviced it.
  1. Super6 ;)
    By HARVZ-6 in forum VT - VX - VU - WH - V2
    Last Post: 13-10-2010, 01:24 PM
  2. Super6 Misfiring when Hot on WOT
    By azza77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2010, 11:28 PM
  3. super6 into vn
    By SUSVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2008, 11:40 PM
  4. super6 in vn
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 09:36 AM
  5. VS super6?
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2005, 04:33 PM
