I'm having difficulties removing the globe socket from the left hand front indicator. Despite having little room to work in because of the wiper filler tube, the socket seems to be stuck fast. I can't budge the right hand side either. I tried removing the indicator unit to gain easier access, but that's not as straight forward as it seems. Can anyone tell me the best way to loosen these sockets up so I can replace the bulbs?
Thanks.
They should be just the normal push in and twist type bulbs.Give them a good push and turn them at the same time.They might be rusted into the holders.If they are ,you might have to remove the headlight and remove them that way.Ive run across a couple of bulb holders that have been rusted up,and I had to break the glass of the bulb and get some needle nose pliers onto the metal part of the bulb to remove it.Hopefully yours wont be that bad.
So the headlight must come out to remove the indicator unit? Thanks mate.
