Results 1 to 5 of 5
Thread: vr engine fuse keeps blowing
    bang_chong is offline hmm new project
    Vk Executive
    Feb 2010
    gold coast
    Default vr engine fuse keeps blowing
    Hi guys, just helping out a mate here. His VR wagon has just started blowing engine fuses everytime he tries to start it. Is there someone who has come across the same thing?
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive got a bodgey wiring diagram for a VR so its a bit hard to follow(its in a haynes manual) ,but from what I can see that fuse is fuse number 25 and it goes to the EFI relay and the ECU.(the VS wiring diagram shows its the same setup the VR also). Maybe try replacing the EFI relay and see what happens then.This relay is under the bonnet near the fuses.
    Vk Executive
    Feb 2010
    gold coast
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the oil pressure switch - they can short internally especially if they've been wet from degreasing and then corroded.
    Vk Executive
    Feb 2010
    gold coast
    Hi ive tried the relay and the car was fine but for 10mins then it done it again.
  1. Engine fuse keeps blowing
    By bkhwong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2011, 05:47 PM
  2. VS BLowing Engine Fuse
    By smakked in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2010, 09:55 PM
  3. Engine Fuse Blowing
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2009, 01:13 PM
  4. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
  5. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
