Results 1 to 3 of 3
Thread: vs fault codes 23 and 63?
    vn executive s2 v6
    Jun 2008
    Default vs fault codes 23 and 63?
    hi i did a check on my ecotec vs yesterday nd it came back with codes 23 (IAT voltage high) and 63 (lh o2 sensor no signal) does this mean i need new sensors? or something else? cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    Try clearing the error codes by resetting the ECU,this is done by disconnecting the battery for a minute or two,then go for a 15 minute drive, and then see if the error codes have returned.If they have, check the wiring and connectors to the sensors.If theres nothing out of the ordinary found, like broken wiring etc,then its most likely them sensors will need replacing.They do wear out like just like any other part and need replacing from time to time.Try to only use genuine holden sensors if you can.I have seen a few problems with cheaper sensors.They can end up costing you more in the long run.
    vn executive s2 v6
    Jun 2008
    thanx for help i will try this, ill probly price up new o2 sensors tho, i have no idea when they were last replaced
  1. fault codes vx
    By dave3838 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2010, 11:17 PM
  2. 99 VT Fault Codes 31, 63, 92
    By VT_Taylor in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2008, 05:13 PM
  3. fault codes
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2006, 07:24 AM
  4. fault codes
    By vlsmoke in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-11-2005, 08:53 PM
  5. Fault Codes Help
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2005, 11:45 PM
