Results 1 to 5 of 5
Thread: where is the fuel pump??
    vs commodore executive
    Apr 2010
    Default where is the fuel pump??
    is the fuel pump located inside the tank out outside?
    Dec 2009
    It's inside the fuel tank on the fuel pickup/fuel gauge assembly. You have to take the whole thing out to change the pump.
    vs commodore
    Oct 2009
    Tamworth NSW
    96 VS Acclaim
    Mar 2010
    Remove the driver side rear wheel and you'll be staring at it right on the fuel tank.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by deXtrous View Post
    Its inside the fuel tank.Its not visible from the outside.Unless its a VN with a long range tank,they had a high pressure external fuel pump as well as a low pressure internal one.
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. Faulty Fuel Gauge/fuel pump unit VU SS ute
    By paul.stewart2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2010, 09:48 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
