Results 1 to 16 of 16
Thread: Fully Manualised VN box into VS... Need help!!
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Default Fully Manualised VN box into VS... Need help!!
    Hey guys,
    Ok everything is in and sorted, or so I thought. I have put in a VN box into my VS, which is fully manualised so no need for TPS/Kickdown. I am Running a T5 manual computer and tune.
    But the car won't Start, I thought it might have been something to do with the big gearbox plug that isn't plugged in anymore... Do I need to loop any wires or what?
    It's not the inhibitor, I tracked it and its all fine.... I'm baffled as to why it won't start. Everything else works, there is power at the injectors etc.. The key just won't turn the engine over, fuel pump goes, and it's not a dead battery its been charged. I doubt the started is gone, it was newish, I will check it...But other than that, What do you think it could be?????
    Has anyone done this, also what did you guys who have manual converted your VS-VY???
    Thanks
    Ben
    There is no such thing as stupid questions, Only stupid people.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    everything in that plug is controls for the gearbox. there should be nothing in it to do with inhibiting.
    does the security light in the dash turn off when you turn the key to on?
    VX II Calais LS1
    Jan 2010
    would think its got to be something to do with the security in the tune, send delcowizzid a pm sure he will sort you out. Hes got a fully manualised auto in his.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I no the tune works I ran it to test it when the normal auto was in.. It was fine.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    check all your fuses, just incase.
    also, see if the starter relay is clicking when you turn the key to start.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    All fuses are fine, I did check, checked pretty much everything, no tick from starter relay, although something is stopping it before that cause I swapped replays over and nothing was different.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I'm running a B&M quicksilver shifter, its the same micro switch for N and P....
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if you swapped ecu's over the bcm may be cutting power to the starter
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I ran the new computer and memcal with the stock box and it ran fine...
    VX II Calais LS1
    Jan 2010
    sticky starter..?
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    tried bypassing the micro switch?
    they can be a bit funny sometimes, and need to be adjusted up.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    It's not the starter, just checked it.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
  15. #15
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    how is it running without a tps? u need that unless you have a maf
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
  16. #16
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I fixed it today, Thanks for the help guys, Turns out the inhibitor switch was unplug deep down under the console.....
    It has TPS just not using it for Kickdown because its fully manualised.
  1. can you get a vy v6 na fully manualised auto?
    By Elite58 in forum V6 Development And Modification
    Last Post: 04-08-2008, 06:23 PM
  2. fully licenced
    By hakhawk in forum The Pub
    Last Post: 07-03-2008, 11:27 PM
  3. fully sic vp
    By juswee_dez in forum VN - VP - VG - VQ
    Last Post: 03-04-2006, 09:44 PM
  4. Fully Sic Mate!
    By Garth in forum Jokes/Humour
    Last Post: 15-04-2004, 10:30 PM
  5. Fully Sik Vl
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2004, 12:39 AM
