Will changing to 3.23 ,3.45 or 3.7 diff gears affect gearbox shift points or cause any other gearbox problems in a VS with 3.07 ratio?
I want to know the same thing for a VZ SV6 with the 5 speed box.
Long story short, yes it will affect your shift points to some degree.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
if you fit a speedo corrector to fix the speedo being out and fit it before the ecu not after its will all shift as normal
Does the Jay car corrector kit go before the ECU? So A diff ratio change has more or less the same effect of the TPS being out when you change to a larger TB as it throws the shift points out due to a different speed to the throttle position ?
what is you car doing?
does this just fix the speedo accuracey?
VR CLUBSPORT WAGONyes a clubsport wagon....
LIVE THE DREAM
