Results 1 to 6 of 6
Thread: Transmission - replacing 5HDD with 4HDD
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Default Transmission - replacing 5HDD with 4HDD
    I've just replaced my buggered 5HDD tranny in my 95 VR V6 with a 4HDD. It now comes up with fault code 83 (TCC PWM solenoid fault) for a few seconds after startup and I have no torque converter lockup. Apart from that it shifts fine and selects all gears correctly.
    Now I know the 4HDD doesn't use a PWM solenoid to lock the converter, while a 5HDD does and i'm assuming this is why i'm getting the fault code. Is there is any modification I can do to get the converter locking up correctly in the 4HDD tranny or do I have to go on the hunt for a 5HDD?
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can fit your old valvebody to the trans or if its wired correct for single solinoid operation may be able to just fit the early tune to tired to think at the moment LOL
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Yeah i'm going to do that! I'm not sure if the solenoids out of the old trans are any good so i'm going to swap the solenoids out of the 4HDD into the 5HDD valve body (apart from the TCC PWM solenoid). Also going to have to swap the internal loom from the 5HDD to the 4HDD I think. Hopefully that fixes up the problem!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Thanks! Had a word with the transmission joint we deal with at work and they pretty much said the same thing today.
  1. 4HDD to 5HDD auto-trans swap
    By tristan8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-08-2009, 08:02 AM
  2. [NSW] WTB: 4hdd Auto transmission
    By jayderichards in forum Swap / Wanted to Buy / Trade
    Last Post: 06-03-2009, 09:16 AM
  3. 4HDD compatable with 5HDD??
    By falcomwreck in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2008, 07:56 PM
  4. trans codes 4HDD and 5HDD
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 02:54 PM
  5. replacing 5hdd auto with 6hdd
    By heathy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2008, 09:40 PM
