Hello all,
I have a VR 6cyl auto, and I need to either fix or replace the fuel and water temp gauges. I have resoldered the 3 pin voltage regulator, and now instead of the gauges not moving at all, the fuel gauge only moves when I bash on the dash, while the temp gauge takes ages to move, if at all.
1) The dash is the normal boring one without the tacho. If I get a tacho dash, can I swap the speedo over to the new dash so I keep my original K's?
2) Is the difference between Level 2 and Level 3 dashes the digital odometer? I'm guessing I can only swap the speedo in a Level 2 dash?
3) Is a tacho dash an easy swap? is there any other modifications that need to be done? Do I need to run a tacho wire to the new dash?
I apologise if these questions have already been answered. If you could point me to the relevant threads, it would be much appreciated.
Cheers.
Have a read through this thread for info about level 3 (digital dash) conversions. You may have damaged your dash when you soldered the voltage regulator or it could be a different problem.
If you get a Level 3 Cluster you can get the Ks programmed to exactly match yours (if you're picky) or just find one with around the same or less kms on it.
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
other than that the level 2 cluster is a stright swap, just plug it in.
Yes you can swap the speedo over.
Yes easy fit to replace L1 cluster.
and 3 Dangerous non ABS VN's
Thanks, folks! I think I'll go for a Level 2, and swap my speedo over.
Cheers!
