Results 1 to 2 of 2
Thread: replacing pedals
    vs exec
    Jun 2008
    Default replacing pedals
    hey guys picked up some vy ss pedals on ebay... replaced the brake pedal easily enough. just wondering how to get the accelerator pedal off.
    thanks
    VS S Ute SeriesIII
    Jan 2010
    Piece of piss if u pull the assembly out of the car. Drop the panel out from under the dash, disconnect the throttle cable from its slot in the pedal arm, remove the 3 nuts securing the assembly to the fire wall and head to a work bench. Release the tension on the spring by pushing it down and to the side. You'll find the pedal is secured by a roll pin. Grab a hammer and a suitably sized punch and knock the roll pin through the arm and remove it. Stick your old pedal in the bin. Fitting of the new pedal is pretty much a reversal of this process, just be sure to make a note of which way the spring came off. Cheers.
  1. [VT-VX] How to fit VY SS Pedals
    By GE4CE in forum Holden Commodore How-To's
    Last Post: 21-10-2010, 05:40 PM
  2. Replies: 13
    Last Post: 08-10-2009, 08:19 PM
  3. SS Pedals
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-06-2006, 06:38 PM
  4. SS Pedals on a SV6
    Last Post: 10-01-2006, 05:04 AM
  5. pedals
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2005, 04:46 PM
