Results 1 to 12 of 12
Thread: Front Suspension
    VS Executive
    Mar 2008
    Default Front Suspension
    Ummm weird noise coming from front right and left hand sides when I go over bumps and turn corners at any speed. It feels like the steering is stuck for a moment then it pops into place. You can feel the floor vibrate when it does the poping sound. I took some pics of the bushes (I think) while the car was not jacked up. Hopefully someone can see something I can't because it looks fine to me :S Going to take it to a mechanic but I want to learn some things for next time so any help would be appreciated
    vs commodore
    Oct 2009
    Tamworth NSW
    Nothing there looks badly worn or dangerous.Looks a bit aged though which could mean the strut assemblies could be worn out and making a noise.It could also be a worn top strut mount or bearing.How many k's has the car done?
    Mar 2008
    looks like your sway bar link pins rubbers are gone ( pic 1 )
    also looks like the radius rod to the lower control arm bushing has a gap in it probably flogged out bush ( pic 8 )
    VS Executive
    Mar 2008
    284,000. At 230,000 I had the front suspension worked on by pedders. The invoice says,
    5823 Pedder Rubber Bush (whatever that is )
    Front Z Bar Bush
    5843 Rubber Bush
    Urethane Panhard Rod Bush
    F - Fitting
    Wheel Alignment
    2 Years ago btw. I know slack with maintenance, girlfriends suck money out of everyone don't they? :P
    VY SS
    Jun 2006
    Albany
    get under the car and grab your swaybar or swaybar links and give them a good tug to see if there is any movement, or get a friend to push down on the front of the car while your underneath and see if you can spot where the noise is coming from or if anything is moving.
    vp le 220 kw5 ltr
    May 2010
    try tightening the chassie braces ,they very commonly work them selfs loose they may look tight but put a spanner on them and give all 8 nut a tweek this usualy fixes that type of noise , and you can generaly feel it through the floor near the trans tunnel when they are loose .( the chassie braces are located between the chassie and the fire wall ,they branch off the chassie on an angle and connect to they firewall ,and are usualy shiney silver )( you will need to get under the car to see them ) another thing to look at is the rack to k frame bolts are tight these also seem to find there way loose and nock and also may be giving you the pause in the steering you mensioned ? good luck let me know what you find
    VS Executive
    Mar 2008
    Yes it moves on the right hand side not the left. When I pull it down it moves about .5-1cm and then makes a metalic tapping sound at the top.
    VS Executive
    Mar 2008
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Quote Originally Posted by TrustNo1 View Post
    That's where the sound is coming from.
    Just be aware - I know you took the photo just to show us where the problem is - that the washers are upside down.
    VS Executive
    Mar 2008
    Oh that isn't my car, I found it on the web because it's too dark here to take one :P
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    Quote Originally Posted by Brett_jjj View Post
    hit the nail on the head i paid about 240 bucks for 2 new top strut bearings and bushes
    VS Executive
    Mar 2008
    Thanks for everyone's help
  1. front suspension help!!!
    By Muzz-VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 11:06 PM
  2. vb front suspension
    By linejockey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-07-2008, 07:31 PM
  3. front suspension
    By impulsesv6 in forum General Discussion
    Last Post: 23-12-2007, 04:09 PM
  4. Front suspension
    By full_noise in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-01-2007, 10:09 PM
  5. VZ Front Suspension
    By MySV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2005, 04:19 PM
