Results 1 to 7 of 7
Thread: Brown sludge in coolant reservoir + coolant level dropping
    VS Vacationer
    May 2010
    Exclamation Brown sludge in coolant reservoir + coolant level dropping
    I am having to fill my coolant tank every two weeks and there is a brown sludge at the bottom of the reservoir. But I am not seeing any other major problems:
    i) The engine never over heats.
    ii) No smoke or steam from under the hood.
    iii) No bad sounds from the engine.
    What is the first thing I should check for?
    I want to check for a possible leak in the cooling system but I'm not sure where to start looking.
    Obviously it would be a major problem if I had a blown cylinder or head gasket - do my problems point in this direction? And if so, how much would it cost to address these problems.
    Thanks!
    Fenners is offline Fenners
    VS II Berlina Wagon
    Apr 2009
    Boronia
    it sounds like a simple leak. brown sludge is the sign of a poorly maintained cooling system. this is not uncommon as it is quiet often overlooked. flush the cooling system and then fill up with 50/50 coolent and water and if a vs bleed the cooling system using the bleed valve. run the car to operating temp and check for leaks. if it was a head gasket the oil and/or water would be a white and milky.
    VS Vacationer
    May 2010
    Thanks Fenners, I'll get onto that. The oil is dark brown, but only because it's in need of a service, so like you said, probably just a leak.
    VY Acclaim Series 1
    Oct 2010
    Default slight oily looking sludge in coolant overflow tank in VY
    I have the same problem on VY I Commodore Acclaim. I occcasionally see a brown oily looking sludge on the dipstick. I suspected a head gasket, but dont see any of the other symptoms associated with this problem like foamy milk shake or smoke bellowing from the exhaust. Engine temp is stable and teh car runs like a dream otherwise. Could this just be an indiation of the car needing a radiator flush? I noticed oil near the CV joint, could thsi be getting into the radiator?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Could be the Intake Manifold gasket, they are common and cause a sludge like substance to appear in the radiator and uses water when there are no leaks.
    You can flush the system and top it up and if it keeps using water and the sludge appears again it is def that gasket.
    VR Wagon
    Oct 2008
    Central Coast, NSW
    I believe the Holden tablets you are meant to add to the cooling system have the same effect. When i bought my VR wagon i had the same problem i did a flush and it never came back.
    Cheers Josh
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Quote Originally Posted by hsv91ss View Post
    +1 for this comment .
    you have a leak in the Inner Manifold Gasket .
    just had one replaced in a VS .
    get this replaced before a coolant flush or else it will dirty the coolant again.
    should be around $150 for a gasket and 2-3 hours labor .
  1. Low level coolant light staying on, even though coolant has been topped up
    By luckyluciano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2010, 08:40 AM
  2. where should the coolant reservoir to radiator cap hose sit?
    By joeyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2010, 11:39 PM
  3. VS coolant go's brown under 12 months
    By Frog201 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2010, 02:09 PM
  4. VZ Dropping Coolant
    By walopa in forum General
    Last Post: 07-01-2010, 10:58 PM
  5. VX L67 - Oil in Coolant & reservoir
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2009, 03:16 PM
Tags for this Thread
