Results 1 to 16 of 16
Thread: Installing ignition barrel, steering lock troubles
    VR, VX, VN Commodore's
    Dec 2008
    Default Installing ignition barrel, steering lock troubles
    i was reading up wonder why the hell my new ignition barrel wouldnt slide in, and then i saw that the ignition lock needs to be down? how do i go by doing this? i push it down with a screwdriver but it keeps springing back up, it wont stay down, any ideas? cheers
    Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
    2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
    Dec 2008
    This is in the VR by the way
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    it can be very tricky try repositioning the steering wheel if you can,, it is very fiddly
    Signature Goes Here
    Dec 2008
    is there a way to hold it down whilst i slide the barrel in? taking off the steering wheel or anything?
    Dec 2008
    and cheers mate will try.
    Dec 2008
    nope, even moving the wheel around and trying all the different spots with the wheel turned the steering lock still wont stay down and let the new barrel slide in
    Vp S1 Exec
    Jan 2010
    needs to be in the on position "ignition lamp" showing on dash i think or acc to slide in
    Sti Subaru Melbourne "the home of Sti"
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    the ones i have done have been a new steering lock as there is nothing i can find to keep it down. you might try ( i have not tried) removing the lock off the colium (the bolt may need to be drilled or cut off some how) and setting it up that way, falling that you will need a new ignition lock, you have the barrell
    Dec 2008
    cheers, dads in adelaide atm, coming back tomorrow with my new Transmission, might see if he can get a Ignition lock too then,,, hes going to Just commodores spares... so im gathering they should have some lol
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Never had a problem with the steering lock, how did you get the old barrel out? If you remove it with the key 'on' like you are supposed to, the steering lock pin stays down.
    Visit my Facebook page
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    not allways , most of the time you have to push it back down and if the lock is a bit worn it wont stay down
    Dec 2008
    id say the ignition lock is stuffed..... just contacted the previous owner and hes the one who took the old barrel out, he used so multigrips and yanked it out apparently, so yeah i think shes stuffed
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you need to take the wheel off and hold the pin in or you wont get it back in been there done that had me stuffed for a while till i poped the wheel off the silly lock bit kept getting in the way of it going in the first one i ground a little off the lock hook so it would go in then realised what needed doing now they are easy
    Dec 2008
    cheers for that, these things are a royal pain in the ass :P
  15. #15
    Dec 2008
    delcowizzid you have a PM mate
  16. #16
    Dec 2008
    can anyone shed some light on what delcowizzid said to do? ive got the steering wheel off but dont really know how to take the indicator and wiper assembly off... or can i get to the pin to push down from here?
  1. Ignition steering lock problem
    By ged in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2011, 11:28 AM
  2. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  3. ignition lock/steering column problem
    By dieseldude in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2009, 07:59 PM
  4. Vp D/s lock barrel
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2006, 10:34 PM
  5. Getting the lock barrel out of a vp
    By joebloggs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2006, 10:41 AM
