Results 1 to 15 of 15
Thread: Indicators - Automatic turn off after turning a corner?
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    Default Indicators - Automatic turn off after turning a corner?
    Recently the ute has stopped automatically turning my indicators off after I turn the corner. I heard what sounded like a plastic 'snap' somewhere inside the steeringwheel housing near the end of the indicator arm. Ever since, when the steering wheel swings back the opposite way as I turn the corner, nothing happens.
    It's nothing major but it is really really annoying having to turn it off after every corner. Any help would be great
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by smokyJ View Post
    REplace the indicator arm. There is a little plastic stick which sits out into the steering wheel cavity, when you push up or down on the indicator stalk, it sticks out. The steering wheel spins around and there is a onther stick on it which knocks the indicator stick and then cancels the indication... long story short, just get a new indicator stalk.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    RazzaCaine is offline Long Gone Now
    Mar 2010
    my indicator arm is dodgy as well. i think the plastic is warped as on warm or hot days the indicator wont self cancel however on colder days it does. its damn annoying!
    VS V8 Ute
    Jun 2008
    SA
    Hey, ive got the same problem, picked up a new stalk but how do I remove the old one?? Ive pulled and pushed and wiggled and she aint comming! HELP haha
    Mar 2004
    Clipped on to the underside of the steering wheel is a plastic cage thingy, it has a part that sticks out, and as the wheel rotates it clips the little tabs on the bottom of the indicator stalk to cancel the indicator.
    So the the indicator stalk could be faulty, (remove it by squeezing the tabs and pulling it away from the column.
    On my VS, replacing the indicator stalk did not fix it, it was the part that sticks out of the cage that was broken off. It cost around $20 for the part, I still haven't fitted as yet.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by parbio View Post
    You need to remove the steering column shroud. Underneath the shroud you will find that it is held together by a number of phillips head screws. Remove screws. Remove shroud. Unclip the indicator armature. If you have cruise control you will also need to unclip a short loom. Remove armature. Replace with new amrmature. Replace shroud and screw back together.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Often it is actually the horn ring that causes this (especially on hot days when the plastic heats and softens) as there is a plastic tab connected to this which contacts with the button in the indicator arm. Once the corners on this tab wear a little and especially on a hot day it will ofter make a ticking sound when it would normally cancel as the two contact but slip past each other as the horn ring tab flexes. The steering wheel needs to be removed to replace the horn ring.
    Mar 2010
    Quote Originally Posted by cander24 View Post
    ok thanks for that, that is most likely the cause of my problem. ill get onto it soon
    VS V8 Ute
    Jun 2008
    SA
    Quote Originally Posted by seraphic06 View Post
    Thanks heaps mate. ill give it ago some stage this wk end!!!!
    VS Sedan
    May 2010
    Hi Gents,
    I've had a look around and there appear to be 2 or 3 sets of things can go wrong with this self cancel.
    In short, my VS indicators have always worked, just stopped self-cancelling. I replaced the stalk thinking that would be the fix, but apparently not.
    I've read of some plastic things sticking out from the stalk (I didn't see them)
    Some form of plastic cage underneath the steering wheel
    Some form of springs sat in the steering wheel
    and finally, actually something to do with the horn ring.
    I have a piece of plastic about an inch long with a curve in it, which does seem to have two lugs protruding from it. But both lugs are within about a cm of each other and come off at 90deg. to the ..... inside (I think) of the curve so I can't see how that would/could be involved.
    So can I ask someone to post up please either a diagram of where these springs go and/or a picture of this plastic cage thingy spoken of and/or a pic of what these little bits sticking out look like.
    Basically a tech diagram which shows how these things fit together would be good please.
    Many thanks in advance.
    Mar 2004
    Sorry, dunno how to post pictures but my description of a plastic cage thingy and someone else's descrition of a horn ring seem to be of the same thing.
    Its a plastic thing that clips on the underside of the steering wheel, has a brass horn contact ring, and the plastic tang that cancels the indicators and a couple of wires.
    I have the box in front of me, part number VS20593 CAM/CANC ST/WHL
    Cost me about $20 last year from Holden(still haven't fitted as yet)
    Aug 2008
    NSW South Coast
    [QUOTE=KDoc;1546976]
    [QUOTE]
    Pic of vs non-airbag horn ring attached
    Attached Thumbnails Attached Thumbnails Indicators - Automatic turn off after turning a corner?-09062009069.jpg
    VS BT1 5LTR ex police commisioners car
    Oct 2009
    GERO WA
    what about high beam flicking on momentarily when i switch the indicator on, this happened on my exa just needed to replace the indicator arm.. same fix here?
  15. #15
    VS Sedan
    May 2010
    THAT looks like the bit that's broken off. Thank you. So I need t replace the horn ring? Which means pulling the steering wheel.
    Bugger.
    Thanks all.
  1. Replies: 2
    Last Post: 24-10-2009, 04:27 PM
  2. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  3. VS V6 96 engine dies when turning a sharp corner please help!!!
    By sspocko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 09:54 PM
  4. VR - 1lt of water gushes out from under dash when i turn a corner
    By -CalaisJay- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2006, 10:20 PM
  5. Indicators not turning off after turn
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2005, 10:04 PM
