Results 1 to 3 of 3
Thread: can incorrectly bleeding air from coolant cause leaks?
    VS executive
    Jun 2009
    Default can incorrectly bleeding air from coolant cause leaks?
    i ask because i just put in a new radiator around a month ago and the coolant level has dropped just a bit since then, im going to go check all of the hoses etc when its light tommorow but im just wondering if it could be anything else such as evaporation (i wouldnt know how this could happen , just throwing it out there)
    anything else i should look for besides the hoses connected to the radiator?
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Expansion and contraction in the overflow bottle is normal.
    So if the overflow bottle was topped up a little 'too' full cold after your new rad install, 'some' of it may have overflowed out of the breather hose when the bottle's level increased from the engines hot fluid expansion.
    Then, once the engine cooled again, the return cap on the rad would of drawn some back, making it appear that you're 'losing' fluid.
    If there is an air lock, this could cause a 'hot spot', which 'could' increase temps, and therefore pressure, forcing more fluid than normal out of the cap and in to the bottle.
    Then a similar scenario as before could happen.
    But I guess a sustained, higher than normal temp and pressure 'could' cause leaks to develop at weak points, like hose fittings and such.
    Check all the fittings you can find, that has anything to do with the cooling system.
    Obviously this would include heater hoses, temp sensors, rad hoses and cap, the radiator itself, and water pump.
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive changed the coolant in these V6's heaps of times, and I never bother about all this bleeding crap.Just fill it up.Ive never had one problem with doing it this way.You can open the bleeder screw if you want, just to be sure.I dont usually bother.Coolant usually needs topping up every now and then,usually more(maybe once a month)in the summer time.Depending on how hot the weather is.
  1. Bleeding coolant
    By tombomb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-12-2009, 09:35 AM
  2. coolant flushing and bleeding
    By GH05T in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2008, 12:31 AM
  3. Bleeding coolant system
    By coolvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 05:25 PM
  4. VS Overheating - coolant leaks
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2005, 09:00 AM
  5. Coolant Leaks Into Interior
    By meh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2004, 12:16 PM
