Results 1 to 9 of 9
Thread: Piston protrusion tolerance
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Piston protrusion tolerance
    I'm building a motor and the pistons are protruding .015". Does anyone know if this is going to cause a piston to smack the head or will the HG thickness be enough to eliminate this risk? I'm not sure how much the HG will compress when it's torqued down.
    vs commodore
    Oct 2009
    Tamworth NSW
    If the block was machined,the machinist should be able to tell you if you can run standard type pistons,or if you will need the recessed top type pistons so they wont hit valves etc.So ask them about it where you had the machining done.If its a standard deck height,and the pistons are the right type for the engine it should all be ok.Maybe also ask them about it where you bought the pistons from.
    Dec 2008
    Pistons are higher compression, but as I understand it, they just make the dish shallower, not increase the height of the piston. The deck was skimmed .004" so bugger all. Thanks.
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Also depends on heads if they have been decked or not, valve springs etc.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    typical ecotec they allways stick proud of the block
    Dec 2008
    Well i'm glad it's not too far out of the ordinary. Heads will be skimmed minimum, Valve springs are Crow 105lb.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    From memory about 36-40 thou min for piston to head. I reckon a head gasket would be around 60 thou.
    You can check compressed gasket thickness by (you have to sacrifice a new gasket) making a hole in it and placing a small lead ball (shotgun pellets work great) and pulling down the head. Then just pull it apart and measure the ball.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i though most gaskets come in around the 040" cometic come in .040" and .060" some perfomance gaskets are thinner, around the .028"
    places that sell headgaskets should know what the thickness is
    Body by Holden, Soul by Brock
    the Legend will live forever
    Dec 2008
    Yep just checked mine, they're .060". Even if they compress half that i'm still ok. Thanks guys.
  1. piston dish cc
    By ari666 in forum V8 Development and Modification
    Last Post: 31-05-2009, 12:18 AM
  2. Front calliper - piston boot refitting and sliding piston into bore
    By Project_Corty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2008, 09:37 AM
  3. piston slap
    By buggzy in forum LSx Development and Modification
    Last Post: 13-03-2008, 09:35 AM
  4. I need a stroker piston
    By gen in forum V8 Development and Modification
    Last Post: 17-10-2007, 07:55 PM
  5. 20% tolerance on breathalizer readings
    By vnberlwagon in forum General
    Last Post: 19-05-2006, 10:40 AM
