Results 1 to 9 of 9
Thread: pacies respray
    vz ss
    Sep 2009
    Perth SOR
    Default pacies respray
    hi guys, just wondering if i can repaint sum pacies at home with the heat coating or does it need to be done in a shop?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    id say engine/exhaust paint from any normal shop supercheap or repco should do the trick, you can buy it in spray cans, just check on the can as to the temps it can withstand it should be specific to exhausts and engines.
    vz ss
    Sep 2009
    Perth SOR
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    it is ceramic coated. If you want it done properly take it to a specialist ceramic coater, otherwise be cheap and use hi-temp enamel.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    the ceramic coating will last longer but costs alot more, you could ring around if you wanted it done.
    Otherwise the higher the temperature engine/exhaust paint you can get the longer it will last if it's not very high temp paint it will just fade and flake off quicker, if your going to spraypaint it yourself you need to make sure it's as clean as possible, use steel wool and fine sandpaper to clean it down once there clean so it'l stick better.
    vz ss
    Sep 2009
    Perth SOR
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Standard Pacies are not ceramic coated just painted blue. Pacemaker sell their blue paint in a spray can. About $300 over here gets you ceramic coating.
    Visit my Facebook page
    vz ss
    Sep 2009
    Perth SOR
    oh yea?
    cheers for that guys
    plz close thread!
  1. 5 litre pacies. Can i bolt up at home?
    By executer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2010, 05:29 PM
  2. [VIC] FS: Worked Buick V6 and custom pacies
    By pow3rslave in forum Parts And Other Items For Sale
    Last Post: 02-10-2009, 04:55 PM
  3. [VIC] WTB: VN V8 EXTRACTORS -PACIES/HM (vic)
    By calaiscruzer in forum Swap / Wanted to Buy / Trade
    Last Post: 04-06-2009, 10:54 AM
  4. [VIC] WTB: Pacies- Tri Y Suit GEN3
    By SAMO-87 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-03-2009, 04:12 PM
  5. VS HSV Extractors VS Pacies........
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2008, 06:04 PM
