Results 1 to 14 of 14
Thread: Wreck help
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Default Wreck help
    Hi all,
    A mate of mine has asked me to help him get his vs ss wreck going to use the motor and box in another car.
    I havent got the remote so the security is on. Have left the reds on until the flashing light goes out.
    There isnt any spark, can hear the fuel pump, didnt bother checking the injector power yet.
    I think the problem is with the part in the pic cause the outer casing was broken in the smash.
    Can someone identify it for me? And is it in the spark system?
    Also do they have a maf? If so can i use a v6 one(have one i can use).
    Heres a pic of what i am working on.
    Any help aprreciated.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    that top picture is of the ignition module, it is required for the engine to run, its like the dfi module on a 6 that sits under the coil pack.
    the maf is up the back in the same spot as a vr, they dont use a air flow meter as far as i know
    vs commodore
    Oct 2009
    Tamworth NSW
    Also that ignition module has to be earthed(or grounded), as its usually bolted to the body which automatically earths it.
    maginoodle's Avatar
    Apr 2006
    thanks, i will try and get another one. I drilled the remaining bolt hole and bolted it on one of the strut mount bolts.
    Dec 2009
    Quote Originally Posted by maginoodle View Post
    It's common for the solder joints where the large transistor package connects to the circuit board to fail, the joint can crack or even start to burn the circuit board. I'd have a look at the inside of it first if the car does not start after you earth it and try. A friend bought one from a wrecker and it stil worked however the solder joints were not far off causing a problem.
    maginoodle's Avatar
    Apr 2006
    Hi all, i tried the ign module on another car and it ran.
    I fixed one wire and put it back on this car and can get it to fire with crc down the t/b.
    I have no injector pulse. Any ideas?
    Cheers Shane
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    security stops injection pulses
    moff_man's Avatar
    Nov 2008
    maginoodle's Avatar
    Apr 2006
    I also replaced the bcm. So the security shouldnt be the prob, the flashing light goes out. I just got a wrecked vs v6 and used the ign barrel, bcm out of it so that i have a working remote.
    Cheers Shane
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Considering you can get it to fire with the CRC indicates the ignition system is good to go.
    Even though you have a working BCM with remote the ECU still needs to be linked to the BCM to make it run correctly. This is what would be holding you back.
    You have four options.
    1. Get the BCM linked to the ECU using a Tech 2
    2. Get a key to match the original BCM
    3. Get a memcal with the security disabled
    4. Get a matching BCM and ECU from a V8.
    BTW I have heard the V6 and V8 ECU are the same just with a different memcal. Has anyone confirmed this?
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vs v8 the ecu is the same as a vr v6/v8 ecu not the same as a vs v6 one
    maginoodle's Avatar
    Apr 2006
    Quote Originally Posted by delcowizzid View Post
    Hi delco, so if i use an ecu from a vr(i have one) and put the memcal(that is the removeable chip in the ecu isnt it?)i should be right to go.
    Because i didnt have the key for the original barrel i changed the complete barrel, so now i have the key and remote that match the bcm i put in.
    It still didnt have injector pulse. So i had another look and realized i didnt put the earth wire back on the ign housing. It now has injector pulse but it only runs for about 10-20 seconds and wont rev. Is that because the ecu and the bcm isnt linked?
    Cheers Shane
    vs commodore
    Oct 2009
    Tamworth NSW
    The VS doesnt need the BCM matched or linked to the ECU with a Tech1 or Tech 2 scantool.Only the VT and later models use this setup.Not the VS or earlier.With the VS,as long as the ignition keyhead matches the BCM,it will start.
    maginoodle's Avatar
    Apr 2006
    Lesson 1 for today- check the simple things.
    Came home today and decided to kick it over, went first go and didnt stall. Tried to work out what i have done and the only thing i can think off is pushing it out of my shed. The rear entrance to my shed is downhill, so i am thinking lack off petrol in the tank.
    Thanks everyone for the help.
    Cheers Shane
  1. [VIC] Parts available from VS wreck
    By deez in forum Parts And Other Items For Sale
    Last Post: 16-09-2010, 05:39 PM
  2. [VIC] WTB: VT-VZ wreck/shell/etc
    By The_Monk in forum Swap / Wanted to Buy / Trade
    Last Post: 31-08-2009, 07:28 PM
  3. What to do with my VB? Wreck or sell?
    By vr94ss in forum General Discussion
    Last Post: 18-02-2009, 07:30 AM
  4. WTB: 5ltr Wreck
    By Pav in forum Swap / Wanted to Buy / Trade
    Last Post: 05-03-2008, 06:54 PM
  5. Wreck value for VR
    By manvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2005, 04:29 PM
