Results 1 to 10 of 10
Thread: 5lt oil pressure problems
    millaz88's Avatar
    millaz88 is offline wishin me v6 was blown :)
    vn commodore
    Sep 2009
    gippsland
    Default 5lt oil pressure problems
    ok i just bought a vr statesman 5lt
    has low oil pressure
    the mechanic replaced the oil pump with a second hand "good" one didnt work said it is the oil pickup
    so what im thinking is to buy a brand new oil pump and a new oil pick up as i have herd the sometimes crack and get blocked with "sludge"
    anyways im thinking when i lift the engine to put the new oil pick up on and stuff im wonderin g if i should take the manifold of aswell and clean it off and put new lifters in and just try clean the oil system all out to make sure its not goin to block up again sorta thing
    ok just wondering whats the best way to clean the oil sludge of and outa my motor?????
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    strp it all down and send it off to a reconditioner where it will be acid dunked, thats the only way to be sure its all clean
    millaz88's Avatar
    vn commodore
    Sep 2009
    gippsland
    i really need it to drive around in as im only borrowing my brother inlaws car atm
    so i cant afford to pull the motor out completly just yet :S
    hopeing there is just a way i can get it done and maybe build a stroker or something while i drive this around in the mean time
    millaz88's Avatar
    vn commodore
    Sep 2009
    gippsland
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    what sort of pressure does it run at they run low pressure 10psi at idle quite often its normal
    millaz88's Avatar
    vn commodore
    Sep 2009
    gippsland
    i dunno what the pressure is to be exact but the hyd lifters are just tapping like hell so there isnt any pressure i suppose?
    the mecanic tested the pressure and said it was the pump but that was no good
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Mine idles at 10 PSI, 40-45PSI at 1750 revs when fully warmed up.
    On a cold start it easily gets to 70PSI.
    Make sure the "tapping" isnt just the injectors pulsing, they're pretty noisy. The 5.0L isnt a quiet engine. at all.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    millaz88's Avatar
    vn commodore
    Sep 2009
    gippsland
    nah its not the injectors i thought that but its deff the lifters way to loud to be them i dont start the engine at all since the problem started and really dont wan2 cause more problems with it by running it with no oil :S
    the machanic said the next step is for him to rip the engine out and fix the oil pick up as it must be blocked but if its not could be guides but yeh thats a bit of money to throw around after doin the oil pump and that didnt fix it so im goin to give it a shot myself i think
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ide be fitting a gauge and checking pressure if its at or around 10psi when hot ide be looking at stuffed lifters or worn out cam lobe if its low on pressure ide say rebuild it most likely worn bearings etc
    millaz88's Avatar
    vn commodore
    Sep 2009
    gippsland
    damit damit damit lol well might have to work something out might try fix it and if that dont work rebuild time
  1. Fuel Pressure Problems
    By 2001_VXSS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2008, 09:04 PM
  2. Oil pressure problems
    By jsracer024 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2008, 09:34 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. Fuel pressure problems
    By sik sv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2006, 10:51 AM
  5. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
