Have a problem on a VR of the LHS high beam only lasting a few days to a wekk.
Anybody got a clue on what the problem might be. I am not an electrical genius.
check the headlight plug, make sure there isnt any corrosion on the pins. also when u put the new globe in make sure you aren't touching the glass part of the globe.
Also check the earth lead to the bulb - it's the black one. Check where it earths to the body hasn't corroded.
Do not touch the globe glass as the finger prints can cause it to overheat.
