is the standard oil cooler on a vs for the engine oil or transmission oil? im considering fitting a transmission cooler to my car when i install my stage 2 shift kit and servo but if it already has one i wont bother
all auto equipped commodores run a trans cooler which is built into the radiator, these are marginal at best. if there is a external cooler fitted it will also be for the trans. holden fitted these as standard equipment on vehicles that are fitted with a tow-pack. they also became standard on the later VS models.
fitting the largest external trans cooler possible is the best advice you will ever get when discussing a 4l60e equipped commodore. these auto transmissions tend to create a lot of heat which is bad.
fitting a stage 2 shift kit with billet servo also works well
Body by Holden, Soul by Brock
the Legend will live forever
ok so im probably better sticking an aftermarket trans cooler on then. i know supercheap auto do ones for v8s of 4.2l+ should i get one of those ones??? mines only a v6 but if you recommend getting the biggest one possible is this the go?
yeh the little black stock ones arn't the best, i got a big alloy aftermarket one.
