Results 1 to 5 of 5
Thread: replacing vs doors
    1992 vp calais
    Mar 2010
    Default replacing vs doors
    found some new panels for my car same colour and in very good condition so i wana change mine over but dont wana pay a panel beater 500 dollars to do it. how do i do this myself the bonnet and doors ?
    96 VS Acclaim
    Mar 2010
    Bonnet is really simple..
    Pop out the clip that holds the black hydraulic arm-things in place. Then there are two nuts to undo on either side of the bonnet, near the windscreen, that have to come out. Don't forget to pull out the window washer hoses before u do any of this.
    Now for the doors, for the front you need to disconnect the wiring first by taking out the kick panel and disconnecting the wiring loom that comes out of the door. Then you have to tap out the door pins. There is a special tool used to do this but I just gripped the pin with vicegrips (on the side where it flays out) and tapped it out with a hammer. Bit awkward but it worked fine. Remember one pin comes out upwards and the other comes out the opposite way.
    Now for the rears, you'll have to disconnect the front seat belts at the base to disconnect their wiring loom, then it's basically the same as taking the door pins out with the same method as above.
    Just remember when you put your door pins back in, don't hammer them all the way down/up to where there is no area to grip it with the vice grips in the future.
    1992 vp calais
    Mar 2010
    wow sounds hard man and sounds like it would be time consuming wana do it for me lol nahh ill see how i go with the bonnt first hen the doorsthanks mate
    vz ss and vs statesman
    Mar 2009
    not hard but you mite need two people for the doors and three for the bonnet just makes it a bit easier
    96 VS Acclaim
    Mar 2010
    I took the doors off myself without much of a problem. Just stick a car jack under one when you take the pins out to support the weight. Bonnet you definitely need two people though.
  1. VR Replacing doors due to accident?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2009, 10:36 PM
  2. FS [VIC]: VS stato rear doors w/ door trims, VS 'S' Ute complete doors and VS Seats
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 28-08-2008, 07:04 PM
  3. Replacing VP Doors
    By Glen_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2007, 12:15 AM
  4. Replacing VN Doors
    By boomnvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2006, 08:45 PM
  5. Replacing VK Doors
    By vkefi in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-04-2004, 06:03 PM
