Results 1 to 12 of 12
Thread: Warning lights
    commodore vs
    May 2010
    Angry Warning lights
    Guys and gals ,i need help! . The other night i drove over what i think was a stump. Coincidently or not ,the next day and , since ive got an engine with an exclamation mark inside it , on my dash. It seems it comes on as the temp fets to the first notch on the temp guage.any link ? Any takers? Cheers
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    O2 sensor wires or speedo ripped out i bet
    vs commadore Ute 1999
    Feb 2010
    The same has happened to mine yesterday, but mine just stays on, if you find something, give me a yell as in i have no clue how to do this Computer check
    could this be the transmition? ? ? i topped up all the Fluids in the car just in case, its still on
    =-+--One Life, One Chance--+-=
    moff_man's Avatar
    Nov 2008
    the idiot light ie the check engine light will only come on when there is a sensor foulting or there is a defective componit with the car ie. crank angle sensor pops to mind. it will not show you anything mechanical like compression and fuel flow issues and stuff like that
    its easy to do just jump terminals 5 and 6 and count the engine light flashes. doing so should save manny hours and lots of dollars in dignostics
    Feb 2010
    ah ok i will remember that, i think i we may have figger out my ! cicle bracket light issue
    "just not mechanical", what do you breaks feel like,
    went to my mate who is a mechanic and it turned out the break fluid was low, and when i topped it up, a little valve had shut so i could not loose any more break fluid. they have to be bleed so it resets th issue
    commodore vs
    May 2010
    commodore vs
    May 2010
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by just not mechanical View Post
    moff does this diag connector look like a black female plug?
    yes under the steering coliumn
    vs
    Dec 2009
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by kyananthony View Post
    have you checked your vitals like oil and water levels?
    they will not put the check engine light on. but is a good idea to check them on a weekly basis
    commodore vs
    May 2010
    and 5&6 FROM LEFT TOP?
  1. Warning lights
    By mat123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2009, 08:03 PM
  2. All warning lights come up
    By eeugene in forum Electrical Wiring / Questions
    Last Post: 19-03-2007, 09:21 PM
  3. Warning Lights ON.
    By VIPVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 07:22 AM
  4. VU Warning lights.
    By TJK-R in forum Electrical Wiring / Questions
    Last Post: 04-09-2006, 04:59 PM
  5. Warning Lights
    By redvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2005, 12:24 PM
