Results 1 to 6 of 6
Thread: Quick question - Body electrical
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Quick question - Body electrical
    Is there an accessory (+v) i can splice into in the driver's door? If so where abouts is it?
    I have power mirrors, does the switch run off the accessory feed line?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    what are you trying to do? running anything piggyback can cause issues later on.
    Dec 2008
    I need to power a gauge off the accessory line, since the gauge is in the door i was hoping to use a wire already in the door. If that's not an option what would you suggest?
    moff_man's Avatar
    Nov 2008
    you could allways run a wire through the rubber passage in the door, possibly the safest way to do it
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you are running a gauge in the door would you need to run the signal wires to it anyway?
    As above, run a new power feed wire to the door.
    Dec 2008
    Yeah i ran the signal wire through the rubber, but then put it all back together and forgot about power. It's a pain to get out so was hoping for an alternative. All good though.
  1. VT engine in boat - electrical question
    By The Dark One in forum Electrical Wiring / Questions
    Last Post: 16-02-2009, 12:21 PM
  2. Quick electrical problem - requires quick answer
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2008, 08:29 PM
  3. Replies: 33
    Last Post: 27-04-2008, 09:25 PM
  4. Throttly body!! Need quick reply!!
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2007, 01:35 PM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
