Results 1 to 7 of 7
Thread: vs serging/lack of power
    vs
    Dec 2009
    Angry vs serging/lack of power
    Hi All,
    I have a vs commodore and it has started to play up. it starts real easy and idles perfictly, but when i take of and go to give it a boot full it starts to chug, and hesitates badly. i have replaced the spark plugs and leads and also the fuel filter it hasnt helped at all. i have checked to see if their was any fault codes but nothing.... when im at a desired speed and keep the foot on the gas steady it runs perfictly when i go to accelarate it start to chug, unless ii put it in 3rd doing like 110km then it is fine. going up any form of hill makes it play up real bad. any help or thaught would be mostly appreciated
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    you have 2 options
    plug lead is firing down the side and shorting out or the coils are on there last legs
    fuel pump is on its way out
    checking the leads is easy, just check for white tracks down the in sides of the plug lead ends (where they go on the plug) also make sure there on tight
    fuel pump will need to be check with a fuel pressure gauge.
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I had my fuel pump die on me, though the idle was rough and hardly accelerated and stalled didn't even allow you to get down the road may be the pump on its way out.
    moff_man's Avatar
    Nov 2008
    it seems to be the seasion for fuel pumps to die. mines diying and several other threads seem to be poiting towards fuel pumps.
    vs
    Dec 2009
    sorry to dound dumb but how do you check the fuel pressure? can i make something up to do the dob
    moff_man's Avatar
    Nov 2008
    needs a fuel pressure gauge. run with a T peice in the pressure line. might be an idea to get a mechanic to check it or see if repco or supercrap sell the gauges
    vs
    Dec 2009
    thanx for your help ill give it a try and ill let you know
  1. vn s2 lack of power.
    By Jordo2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 05:09 AM
  2. Lack of power
    By JBDrifter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2007, 12:53 AM
  3. Lack of power
    By bush_basha in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2007, 02:56 PM
  4. Lack of power for stroked 4.3L VR
    By Moredhel84 in forum V6 Development And Modification
    Last Post: 18-10-2006, 07:44 PM
  5. Lack of Power & Response VT S2
    By shane1806 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2005, 09:29 AM
