Results 1 to 8 of 8
Thread: Trans Imploded - Options on 355 VS Clubby
    VS Clubsport, 81 DeLorean
    Dec 2007
    Default Trans Imploded - Options on 355 VS Clubby
    Hi All,
    After a bit of advice. My transmission went on me the other day, and i am told by the transmission shop that it is around 3K for repair. I can't afford the repair immediately, so am going to lay the car up for a few months while i work out what to do.
    I am told that the standard auto boxes are fairly prone to failure, even with the stronger internals, so not sure if i want to throw 3K at it, only to know there is a chance of it blowing again.
    I am wanting a few opinions on what i should do. I was thinking manual conversion, but am told that the 5 speed V8 gearbox for the VS wont hold up to the power that my car is putting out. Are there any other stronger options? Car is putting out about 410hp at the flywheel.
    Paul
    VS L67
    Sep 2007
    BrisVagus
    T56 Road Race box from Mal Wood automotive, it will put up with the HP, but it will lighten your wallet considerably.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    for a manual conversion i'd recommend a T56 6speed box with some 3.9's or 4.11's gears in the diff.
    the standard 4l60e is some what prone to failure (i'm led to believe it has something to do with the huge gear ratio difference between 1st and 2nd in the auto). you could upgrade to the 4l65e or even a 4l80e as these are stronger versions, however $$$ are always a issue
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs commodore
    Oct 2009
    Tamworth NSW
    If the auto is built properly using performance parts, and a good transmission cooler is used, it will easily handle that power and should last for a fair while .A standard manual box wont last long though behind that sort of power.Especially if it gets driven hard.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    a built T700r4 or electronic 4l60e is as strong as a built T350 most people go wrong on the auto settings in the ecu or dont touch them at all causes them to fail more than any other cause .more torque at less throttle but the tunes still setup for less torque so shifts slack at lower pressure and slips for longer all leads to dead boxes if you seen what my T700 has been through they are strong as hell
    Jun 2006
    Western Aus.
    If you want to keep it auto, do a Turbo 400 conversion. A well built 400 will handle anything you can throw at it, you loose overdrive but will never blow it up. (this can be done for between $2500-3000)
    If you want to convert to manual, a TKO-600 will do the job nicely.
    Hot Lap Motorsport
    в∞ѕтεכ √&
    Jul 2008
    NZ
    T400 is good but the lack of overdrive soon pisses you off just ask plymouth_hemi_69
    Apr 2006
    Auckland NZ
  1. fitting vy clubby indicator (stalks) 2 my vs clubby
    By clubby 185i in forum Electrical Wiring / Questions
    Last Post: 06-04-2010, 11:53 PM
  2. VX Clubby Auto Trans Issues
    By StealthX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2009, 08:41 PM
  3. [SA] To TRADE. VT Clubby front bar and VX clubby side skirts
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-03-2009, 11:48 PM
  4. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  5. options
    By 3800_man in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-05-2006, 07:31 PM
