Results 1 to 17 of 17
Thread: Replacing VSS (Vehicle Speed Sensor)
    VS vacationer sedan
    Apr 2006
    Red face Replacing VSS (Vehicle Speed Sensor)
    Hi All
    I have an error code 24 on my VS auto trans Commodore, so have a new VSS to install.
    But I can't find/see where it goes? I understand it's on the left hand side of the rear extension part of the trans - but I still can't see it!
    Anyone done this?
    Is it a straight old out/new in procedure.
    Are there any brackets etc to remove to expose the VSS - maybe why I can't see it. Just have car jacked-up on ground - no hoist available.
    Any/all help appreciated - especially with pics.
    Alanm
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    it's at the back end of transmission i think on the drivers side, if you still have trouble i do have a photo i can post.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    i thought it was on the extension housing on the passangers side hidden in a little, there will be a loom pluged in to it and its held in with a half moon clamp (like the old 202 trans speedo) it has a nylon gear and with a electronic bit on the top that unscrews.
    verry dirty auto but its there top left of pic
    Attached Thumbnails Attached Thumbnails Replacing VSS (Vehicle Speed Sensor)-026.jpg   Replacing VSS (Vehicle Speed Sensor)-026.1.jpg
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by The1 View Post
    it's after the back of the engine front of transmission i think on the drivers side, if you still have trouble i do have a photo i can post.
    would love to see this photo...
    Moff_man is correct.. back of box passenger side..
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Also be prepared to have some transmission fluid come out as well.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by bandit10 View Post
    Hmm sorry i havn't had to change one myself yet, but this is straight out the vs gregorys manual, it must be wrong then
    VS vacationer sedan
    Apr 2006
    Many thanks everyone. Installed new one today and all is well. Changes gears when it should now!
    For the record the Gregorys pic is correct. VSS is on the driver's side...maybe it's on the passenger side on a manual trans.
    Thanks again
    Alanm
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by AlanM View Post
    Thanks again
    Alanm
    Thanks AlanM what model is yours? Maybe different models have it on opposite sides? I went and checked mine it's also on the drivers side, it's a 6HDD.
    Moff_man what model is the one in the pic with it on the left?
    VX II Calais LS1
    Jan 2010
    it's after the back of the engine front of transmission.
    you said the back of the engine front of trans... its at the rear of the trans as shown in your picture, no where near the engine
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    moff_man's Avatar
    Nov 2008
    that one in my pic was a 4hdd also my 5hdd in my wagon is in the same place. may of changed for vs but i thought vr vs trans were the same, my apologies
    vs commodore
    Oct 2009
    Tamworth NSW
    Heres a pic of a VP auto.It has the speed sensor on the left side.
    [IMG][/IMG]
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    mines a series 1 1995 vs 6hdd so might have changed with vs, i guess the boxes are the same though and would still fit and work the same.
    VS vacationer sedan
    Apr 2006
    Where does the box model number come from? Where would I find it. The1 says he has a 6HDD.
    My VS is a Series II Vacationer sedan, late 1996 model.
    Alanm
  15. #15
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    look in from the passengers side in the engine bay it's up the back on a label on the box itself.
  16. #16
    VX II Calais LS1
    Jan 2010
    if you look at the trans from the engine bay on passenger side of the bell housing there should be a white sticker that says 5HDD 6HDD etc if its a V6 or if its a V8 will say 5HBD 6HBD etc..
    edit: The1 beat me to it lol
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    Alanm
    If you look at the pics The1 posted,it says 6hdd in black, stamped on the transmission itself up the top on the bell housing,just to the right and up a bit from the oil pipe unions..Look in this area to find what yours is.The VP trans picture above shows a sticker in a similar place to show its type.
  1. code 24 vehicle speed sensor
    By Vt-Brrrlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2009, 12:14 AM
  2. Vehicle Speed Sensor
    By JoeNess in forum Electrical Wiring / Questions
    Last Post: 11-05-2008, 09:25 PM
  3. Vehicle Speed Sensor
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-06-2006, 11:45 PM
  4. Vehicle Speed sensor
    By MJohns in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2006, 05:22 PM
  5. vehicle speed sensor for vl
    By customcaraudio in forum Electrical Wiring / Questions
    Last Post: 13-01-2005, 10:58 PM
