Results 1 to 12 of 12
Thread: Will a level 3 dash be able to work on a level 1 loom?
    VR V6 UTE
    Mar 2010
    Default Will a level 3 dash be able to work on a level 1 loom?
    Question, will a level 3 dash connect to a level 1 loom? or will only a level 2 fit it
    as I dont have the extra wires as the level 2 does, ie speed alert wires etc.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    level 2 will work level 3 needs the patch loom
    there is a few good threads goin round about dash upgrades
    VR V6 UTE
    Mar 2010
    Thanks for that, just wasnt sure if it will patch into a level 1 loom. OMG I dont like electrical stuff
    moff_man's Avatar
    Nov 2008
    if you think its a bit hard, someone on here might be able to make a loom up and post it to ya on a changeover type thing, i could do it but i dont have a spair loom and im in the middle of nowhere
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    If you just want to upgrade to the level two cluster to have a tacho then it will plug and play with the level 1 loom no worries. As above, if you want to fit the level three cluster the loom will have to be customised as you'll need an extra plug grafted into the loom and the plug for the hvac unit is different compared to the level 3 loom as it has climate control. 88greenvn on this forum makes them and I can certainly recommend him. Hope that helps.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    A level one loom can be used, all you need to do is cut and tee-join a few wires. The two extra plugs you need should come with the cluster - or if you are taking it from the donor car yourself, cut your tails as long as you can.
    The headlight switch in the level 3 dash surround wont work properly with your low bcm, but its exactly the same size and shape as the one from your old surround, so you can swap them. Also the rear demister switch wont connect to level 1 loom, you will need to use the one you already have
    I did it this weekend. pretty cool mod.
    VR V6 UTE
    Mar 2010
    Hi Andrew426, thanks for the info about the light switch, I was wondering why the light adjuster wasnt working properly, now I can just swap it over
    Everyone one here has been really helpfull, I was able to install the level 3 dash today using a diagram that has been posted on here by Greenvn88, very helpfull.
    The only thing I cant get to work is the speedo I have a yellow with black strip wire left out, so mabey that goes somewhere? Thinking of useing the demister
    for something else.
    Again thanks everyone for your help
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by dk4400 View Post
    for something else.
    The speedo is the purple white wire - check that one first. The yellow black wire supplies the trip computer with instant fuel read out. It goes to slot A2 on the engine harness plug.
    and 3 Dangerous non ABS VN's
    VR V6 UTE
    Mar 2010
    Quote Originally Posted by 88GreenVN View Post
    Hey 88GreenVN, do you have a diagram or something showing where the yellow black wire goes? also what and where should I be looking at with the purple white wire?
    Thanks for your help it made the job easy enough even for me I am going to post a big thanks to Greenfoam for doing me a tune for the ute to, just waiting to take it for a proper
    drive once its on the road to get the full effect and see how its going, but already its made a huge difference to it
    88GreenVN's Avatar
    Jun 2006
    Connector 2 Number 2 purple white wire from the 4th plug. Check that for continuity.
    The engine loom plug is white/clear colour and has the 2 top corners clipped. It's located under the glove box - take your air vent off and the glove box out. It will be easier to see then. It's the only empty slot in the plug and will have a yellow black wire out the other side. It's the only yellow black
    VR V6 UTE
    Mar 2010
    Thanks for that, I found some plugs that arnt connected to anything, near the ECU, not sure what they are for, the ute has been converted from column auto to
    5 sp manual, maybe that has something to do with it? will check it out in the morning.
    Thanks 88GreenVN.
    88GreenVN's Avatar
    Jun 2006
    Thanks 88GreenVN.
    If you unbplug the engine loom the car will not start. Easy way to check - and it's the only yellow black wire around as far as I know.
  1. level 3 dash loom fs
    By millaz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2009, 11:27 PM
  2. [VIC] VR-VS level 3 dash wiring loom
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 22-03-2009, 07:55 PM
  3. VS Level dash wiring loom question
    By shanhsv in forum Electrical Wiring / Questions
    Last Post: 01-05-2008, 09:04 AM
  4. level 3 dash, who knows how to work it?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2008, 08:49 PM
  5. vr/s level 3 dash loom
    By markovr in forum Parts And Other Items For Sale
    Last Post: 06-01-2007, 08:06 AM
