Results 1 to 5 of 5
Thread: VR Calais - strange noise on braking
    VR Calais
    Aug 2009
    Default VR Calais - strange noise on braking
    This has just started to happen - very hard to describe this strange noise which sounds like it's coming from under the front passenger seat.
    Only happens when the car is moving.
    It happens every time I press the brake pedal, unless I press it very very slowly.
    It's a sort of metallic click followed by sort of hiss/rattle - lasts no more than 1 second - not a big noise - only thing I can compare it with the is sound you'd get from a coiled spring sliding down a rod and hitting the end.
    Brakes are working just fine though. But this noise is driving me crazy!
    Can't see anything underneath that could be causing it
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VR Calais
    Aug 2009
    Default strange noise
    Quote Originally Posted by The1 View Post
    you sure it's not just brake squeel or a stone stuck in the brakes.
    Nope - definitely not those. Sound comes from LHS and you'd swear it was from under the front passenger seat ... no sound from pedal area at all, and I know what a stone sounds like.
    It kinda sounds like a relay clicking - but slowly.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id be removing the wheels and having a good look at the calipers,pads and disks,maybe even remove the pads while you are there to check them out properly.
    VR Calais
    Aug 2009
    Default solved - but very red face
    As crazy as it sounds it turned out to be the spare ciggy lighter sitting on a paperclip stored in the centre console!!!
    No wonder there was no noise when the car wasn''t moving.
  1. Grinding noise upon braking
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2011, 03:03 PM
  2. Very strange noise from console in VT Calais
    By achtungspitfire in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2008, 06:04 PM
  3. Weird noise when braking
    By QWK-11E in forum V8 Development and Modification
    Last Post: 20-10-2006, 01:34 AM
  4. Clunking noise while braking
    By Busrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 09:37 PM
  5. Strange sound under heavy braking VXII S
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2005, 11:35 PM
