Results 1 to 14 of 14
Thread: Why does an over-sized exhaust kill bottom end power?
    96 VS Acclaim
    Mar 2010
    Default Why does an over-sized exhaust kill bottom end power?
    Hey was reading up on extractors and exhausts and it was said an exhaust over 2.5" will kill bottom end power, but help top end.
    Anyone know why?
    vs commodore
    Oct 2009
    Tamworth NSW
    It is to do with the gas flow,when exhaust gas is dumped out of the motor into a big pipe at low revs, theres no back pressure and hardly any flow.The inertia of the exhaust gasses going out of a good proper flowing exhaust pipe, helps pull along the next lot of exhaust gas thats coming out of the engine ,extractors work on the same principal,hence the name extractors.The back pressure and flow is lost in a big pipe. An over exhausted engine will be worse on fuel too.
    96 VS Acclaim
    Mar 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    I learned this the hard way,I had an XB Falcon V8 that had a single exhaust system.I fitted a duel exhaust system and it absolutely killed the engines bottom end power.It went better up near the redline,but who drives around near the redline all the time.I went back to the single system real quick.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It's not back pressure that you need, it's exhaust velocity. A bigger system will slow exhaust velocity down and create back pressure just like a system that is too small. If you can keep the exhaust gas moving as fast as possible, this makes room for the clean air/fuel mix so you gain more bang which equates to better torque. The faster you can get the spent gases out, the faster you get clean air in.
    There is a misconception that back pressure equals better bottom end. A smaller eaxhust system moves the gas faster at lower revs than a big system does, this is what retains bottom end.
    Visit my Facebook page
    Scido is offline Banned
    VQ Statesman Caprice / VY Storm
    Apr 2010
    Perth, WA
    Quote Originally Posted by Brett_jjj View Post
    Semi related reply
    I bloody hate those ads in mags and tv where they say the new hsv or new ford has 320kw at 7000rpm, Like who the **** is goin to rev there car to 7000rpm haha
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Ive got a good story on exhaust systems in a magazine somewhere and theres a bit in it where some F1 mechanics talk about different exhaust systems on F1 cars and they talk about the engines needing some residual back pressure and high gas flow speeds.
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    It's like farting in a small space has more effect than farting in an open area.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    some newer cars now have a flap that opens at x rpm and allows extra flow in the exhaust.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by moff_man View Post
    I think that's more to do with EPA noise regs over anything else.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There ya go....quite a good read and explained rather well. Saved me a lot of typing.
    moff_man's Avatar
    Nov 2008
    Reaper
    alloytech captiva's are not louid, they have the seccont exhaust that opens when you get up em. at idle only one side is working till you get up it for the exact reasion as this thread is about, flow up higher in the rpm's
  1. different sized tyres
    By vn5sp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2010, 12:08 PM
  2. Would having different sized rims on front and back be bad?
    By Maxxiz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2009, 07:03 PM
  3. turbo v6 , l67 bottom end or rebuilt ecotech bottom end?
    By petezor in forum V6 Development And Modification
    Last Post: 25-01-2007, 12:16 AM
  4. VE Mid-Sized Hatch?
    By Evman in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-01-2006, 07:22 AM
  5. DIN sized
    By Person_A in forum Car Audio
    Last Post: 08-03-2005, 10:25 PM
