Results 1 to 11 of 11
Thread: MAIN belt that drives everything in my vr?????
    VR commodore
    Mar 2010
    Default MAIN belt that drives everything in my vr?????
    ok so i have no idea what this belt thing is called... but i have replaced my old one with a new belt as one of the ribs on it had broken off
    my car is making like a clunkin noise but i cant fig wat it is... thought it was the water pump but i replaced that and its still making a noise.
    ... i was under the bonnet today trying to find the noise n i seems like my belt must b jumpin coz its starting to rip of like the last belt...
    its not like its slipping coz the tention is lose i wonder if wat eva is making the noise is making it happen???? but i have no idea
    does anyone have a idea on whats happening?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like it is the harmonic balancer. The big pulley at the bottom of the engine. Take the belt off again and give it a wobble, if it moves it is stuffed.
    Visit my Facebook page
    96 VS Acclaim
    Mar 2010
    Had a similar issue when I replaced a belt... Make sure the belt is 100% straight amongst all the pulleys. May help you but don't count on it. I only had a very slight ticking/thumping nose, but I readjusted it and it's fine now.
    VR commodore
    Mar 2010
    iv tryed to move the big pulley but doesnt budge wen i try n move it?? but thanks guys
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Did you get the right belt?
    also the tensoner is possibly stuffed, mine was so i changed it
    96 VS Acclaim
    Mar 2010
    If you need to inch the belt over a tad, use a flat head screw driver and lever it in the direction you want to go.
    VR commodore
    Mar 2010
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    S/C VX Calais
    Apr 2010
    canberra
    Default -
    i had the same psoblem... the part that ripped off get caught in the air compressor pump.. so i pulled that out and changed the harmonic balancer and it works fine now
    VS Berlina
    Jul 2009
    Melbourne, VIC
    The pulleys are fairly cheap (about 30 bucks if I remember rightly). When I replaced my idler pulleys I lost a lot of my annoying engine noises
    vs commodore
    Oct 2009
    Tamworth NSW
    If you have the metal type pulleys, instead of buying complete new pulleys, just replace the bearings in the idler and tensioner pulleys.The bearings are about $8 each..The plastic type pulleys are throw away once the bearing gets noisy..I replaced the bearings in these 3 pulleys a couple of weeks ago,heaps quieter now,you can hardly even hear the engine at idle.
  1. Replies: 3
    Last Post: 02-02-2010, 04:25 PM
  2. Naturally aspirated V6 accessories belt versus L67 supercharger belt
    By VSSECO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2009, 09:23 AM
  3. belt tensioner throwing belt out of line. HELP!
    By t-rav in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2009, 01:16 PM
  4. Main engine belt too short!
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2008, 12:45 AM
  5. Main Belt replacement
    By Scuba in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2007, 10:53 AM
